I have zigbee lights from zemismart
https://www.zemismart.com/products/-447
https://www.zemismart.com/products/-435
I have the MOES bridge. The lights work correctly in MOES. Although the music feature in MOES does not work correctly. Once it starts flashing is just continues to flash regardless of sound. But that is a separate issue.
I have this connected to smartthings via Matter gateway. I can change colors in smarthings. However if I attempt to change the temperature its does not go through.
The color temperature is "white by default which is temerature 4016k
In the below code I request 3000k and it stays 4016k
1. received command: {"args":{"temperature":3000},"capability":"colorTemperature","command":"setColorTemperature","component":"main","positional_args":[3000]}
2. sending InteractionRequest: <InteractionRequest || type: INVOKE, info_blocks: [<InteractionInfoBlock || endpoint: 0x04, cluster: ColorControl, command: MoveToColorTemperature, data: Structure: {options_override: \x01, color_temperature_mireds: \x01\x4D, options_mask: \x01, transition_time: \x00\x00, }>]>
3. received InteractionResponse: <InteractionResponse || type: COMMAND_RESPONSE, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x04, cluster: ColorControl, command: MoveToColorTemperature>>]>
4. received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x04, cluster: ColorControl, attribute: ColorTemperatureMireds, data: Uint8: \xF9>>]>
