Need Help with Unlocking Smart Lock Device via BLE in iOS App
abhi165
Hi everyone,
I have a smart lock device with the device ID d7446bvfiszjytea. I’m trying to add functionality in my iOS app to connect and unlock this device. Below is my current implementation:
class ConnectionManager: NSObject, ThingSmartBLEManagerDelegate {
    var siteID = Int64()
func start() {
    if !ThingSmartUser.sharedInstance().isLogin {
        ThingSmartUser.sharedInstance().registerAnonymous(withCountryCode: "+91",
                                                          userName: "guest",
                                                          success: {
            self.loginAndFetchSiteDetails()
    } else {
func createSite(siteName: String, geoName: String, rooms: [String], latitude: Double, longitude: Double, completion: @escaping (Int64?) -> Void) {
    ThingSmartHomeManager().addHome(withName: siteName, geoName: geoName, rooms: rooms, latitude: latitude, longitude: longitude, success: { siteId in
        print("Site created successfully with ID: \(siteId)")
        completion(siteId as? Int64)
    }, failure: {
        print("Failed to create site: \($0)")
        completion(nil)
func loginAndFetchSiteDetails() {
    let siteName = "MySite"
    let geoName = "MyGeo"
    let rooms = ["Living Room", "Bedroom"]
    let latitude = 37.7749
    let longitude = -122.4194
    createSite(siteName: siteName, geoName: geoName, rooms: rooms, latitude: latitude, longitude: longitude) { siteId in
        if let siteId = siteId {
            self.siteID = siteId
            ThingSmartBLEManager.sharedInstance().startListening(true)
func didDiscoveryDevice(withDeviceInfo deviceInfo: ThingBLEAdvModel) {
    ThingBLELockActivator.shared().activeBLELock(deviceInfo,
                                                 siteId: Int64(siteID),
                                                 success: {
        print("Device activated: \($0)")
        // Attempt to unlock the device
        let lockDevice = ThingLockDevice.shared()
        lockDevice.unLock(withSiteId: self.siteID, deviceId: "d7446bvfiszjytea", success: {
            print("Unlock successful")
        }, failure: {
            print("Unlock failed: \($0)")
        // Alternative method
        let ble = ThingSmartBLELockDevice(deviceId: "d7446bvfiszjytea")
        ble?.autoConnect()
        print("BLE connected: \(ble?.isBLEConnected() ?? false)")
        ble?.addMember(withUserName: ThingSmartUser.sharedInstance().userName,
                       allowUnlock: true,
                       timeType: .permanent,
                       effectiveDate: .now,
                       invalidDate: Date() + 10000,
                       success: {
            print("Member added: \($0)")
            ble?.bleUnlock("guest-171839258741392446433", success: {
                print("BLE unlock successful")
            }, failure: {
                print("BLE unlock failed: \($0)")
        }, failure: {
            print("Failed to add member: \($0)")
            }, failure: {
    }, failure: {
        print("Device activation failed: \($0)")
I am able to successfully connect and activate the device, but I am having trouble with unlocking it. I’ve tried two methods to unlock the device, but both of them are failing.
Method 1:
}, failure: {
Method 2:
ble?.autoConnect()
               allowUnlock: true,
               success: {
    }, failure: {
}, failure: {
    }, failure: {
Both methods return different errors:
•	Method 1: API or API version error
•	Method 2: product dp define error, can't find ble_unlock_check、bluetooth_unlock code
Can anyone guide me on how to properly unlock the device? Any help would be greatly appreciated.
sega
Re: Need Help with Unlocking Smart Lock Device via BLE in iOS App
Have you managed to make any progress on this? I have the same problem...
