Problem mit tuya cloud und homey
Wi-Fi devices, Cellular devices, WukongAI device, Development board, TuyaOS transplant and so on.
admin_
Hello everyone, I have integrated a door sensor via the Smart Life app. I then set up the Tuya Cloud. I could also add a sensor. Unfortunately, this does not update the value in the homey APP (smart home). This will be updated in Clous. Only when I restart the app on homey is this value updated. If the sensor is moved, nothing happens again. The current value is only there again after restarting the APP... What could be the reason? thank you in advance
Re: Problem mit tuya cloud und homey
hi,
Could you please provide more information about this issue? such as:
  1. a vedio of this issue and the time when it happened, we not clear about it.
  2. device id of the door sensor, we can check the report history on iot platform.
  3. the log of the door sensor, wen can check whether the device works normally.
