REFLASH WBR3 Modules
Developer Platform features usage and feedback.
mohsen133
Hi guys,
I got a free license and activated it
And I don't know how to write the license on the WBR3 module (I took it from another Tuya device)!
I use TYProductionToolkit software.
How do I enable WBR3 mode for programming?
I connected RX TX GND VCC to TTL-> TX RX GND VCC but it doesn't program
I think I have to do something else to enable it
Please advise
Many thanks for considering my request.
Re: REFLASH WBR3 Modules
Hi,
We have a document but it worte in chinese,pls wait for a moment, we will send it to you today.
Hi,
We have some questions about your issue.
  1. What type of free license do you have? Is it a UUID & AuthKey list or a token?
  2. Where did you obtain the WBR3 module? Is it being used on another device? Has it been activated to the Tuya Cloud? If so, the programming was disabled after activation to the Tuya Cloud for 15 minutes.
  3. You can use the PC tools located in the "pc/tools/" directory of the TuyaOS Development Kit to erase all of the flash and burn the QIO firmware at address 0x0.
  4. If the free license is a UUID & AuthKey list, you can add it to your source code; if the free license is a token, you can use the TYProductionToolkit.
Please let us know more details so we can better assist you with your issue.
mohsen133
Hello
I review what I did
1- I got a license according to the attachment :
and I Downloaded "AmebaZ2" app
and "Flash Erase" WBR3 chip with file "3.png"
and burn it with "imagetools_flashloader_....bin" see "4.png" attachment file
and then burn it with file "oem_8720cf_rnd_zero_dctrl_switch_QIO_1.0.1.bin" see attachment file "2.png" (credential .bin file)
So far everything has gone well and I see OK in the AmebaZ2 chip burner App.
and I tried to burn "WBR3" with "TYProductionToolkit" see the attachment file "5.png"
THAT I DIDN'T BURN WBR3 with TYProductionToolkit
what is my fault?
                                 My wiring for "AmebaZ2" was:
Module pin Serial port pin
A_0 VCC3.3V
LOG_RX TX
LOG_TX RX
VCC VCC3.3V
GND GND
RXD VCC3.3V
                                My wiring for "TYProductionToolkit" was :
TX RX
RX TX
GND GND
VCC3.3V VCC3.3V
What is my fault?
IS THERE ANY MOVIE (STEP-BY-STEP) ABOUT THAT?
I was forgetting that the total time to complete was not more than 15 minutes
