1)开发包全称:tuyaos-iot_3.8.1_bk7231n_wifi-ble-com_1.2.8.tar.gz
2)问题现象:请问下如何正确注册“tuya_ble_reg_raw_scan_adv_cb()”这个函数才能查看原始的蓝牙广播数据(非涂鸦 Beacon协议)。目前在example工程的 “example_ble_remote.c”文件里添加的,可能方法不对没有起到作用。求教正确方法。
【已解决】【TuyaOs】请教下如何扫描蓝牙遥控原始数据
- chenyisong
Re: 【求助】【TuyaOs】请教下如何扫描蓝牙遥控原始数据
我在BK7231N上测试了这个功能是可以正常接收到数据的,测试代码如下:
#include "tuya_bt.h"
VOID ble_raw_scan(TAL_BLE_ADV_REPORT_T *scan_info)
TAL_PR_DEBUG("rssi:%d", scan_info->rssi);
for (uint32_t i = 0; i < scan_info->data_len; i ++) {
TAL_PR_DEBUG_RAW("%02x ", scan_info->p_data[i]);
TAL_PR_DEBUG_RAW("\r\n");
* @brief
* @param[in] data: data
* @param[in] len: data len
* @param[in] type: type
* @param[in] mac: device mac
* @return none
STATIC VOID ble_receive_callback(UCHAR_T *data, UCHAR_T len, UCHAR_T type, UCHAR_T* mac)
INT_T i = 0;
TAL_PR_DEBUG_RAW("ble_receive_callback: ");
for (uint32_t t = 0; t < len; t ++) {
TAL_PR_DEBUG_RAW("%02x ", data[t]);
return;
* @brief ble scanf adv bind check callback
* @param[in] type: bind type for bluetooth remote controller
* @return OPRT_OK
STATIC OPERATE_RET ble_scan_adv_bind_check_callback(TUYA_BLE_BIND_TYPE type, UCHAR_T *data, UCHAR_T len)
INT_T i = 0;
TAL_PR_DEBUG("----------------scan adv bind check cb-----------------");
TAL_PR_DEBUG("ble bind type : %d, data len: %d", type, len);
for(i=0;i<len;i++) {
TAL_PR_DEBUG("data[%d] : %d", i, data[i]);
return OPRT_OK;
* @brief ble scan adv bind notify callback
* @return none
STATIC VOID_T ble_adv_scan_bind_notify_callback(TUYA_BLE_BIND_TYPE type, int rslt)
TAL_PR_DEBUG("------------------ble scan adv bind notify cb----------------");
TAL_PR_DEBUG("ble bind type : %s", (type == TUYA_BLE_OP_BIND) ? "bind" : "unbind");
TAL_PR_DEBUG("result : %s", (rslt == 0) ? "success" : "failed");
return ;
* @brief ffc task
* @param[in] param:Task parameters
* @return none
VOID ble_remote_init(VOID)
OPERATE_RET rt = OPRT_OK;
TUYA_BLE_SCAN_ADV_HANDLE_CBS ble_scan_cfg = {0};
ble_scan_cfg.bind_check = ble_scan_adv_bind_check_callback;
ble_scan_cfg.bind_notify = ble_adv_scan_bind_notify_callback;
/* Register callback function for advertisement scanning data processing */
TUYA_CALL_ERR_GOTO(tuya_ble_reg_app_scan_adv_cb(ble_receive_callback), __EXIT);
TUYA_CALL_ERR_GOTO(tuya_ble_reg_app_scan_adv_handle_cbs(&ble_scan_cfg), __EXIT);
TUYA_CALL_ERR_GOTO(tuya_ble_reg_raw_scan_adv_cb(ble_raw_scan), __EXIT);
/* set bind window (s) */
tuya_ble_set_bind_window(30);
__EXIT:
return;
* @brief SOC device initialization
* @param[in] none
* @return OPRT_OK on success. Others on error, please refer to "tuya_error_code.h".
OPERATE_RET __soc_device_init(VOID_T)
#if (defined(UUID) && defined(AUTHKEY))
ws_db_init_mf();
/* Set authorization information
* Note that if you use the default authorization information of the code, there may be problems of multiple users and conflicts,
* so try to use all the authorizations purchased from the tuya iot platform.
* Buying guide: https://developer.tuya.com/cn/docs/iot/lisence-management?id=Kb4qlem97idl0.
* You can also apply for two authorization codes for free in the five-step hardware development stage of the Tuya IoT platform.
* Authorization information can also be written through the production testing tool.
* When the production testing function is started and the authorization is burned with the Tuya Cloud module tool,
* please comment out this piece of code.
WF_GW_PROD_INFO_S prod_info = {UUID, AUTHKEY};
TUYA_CALL_ERR_RETURN(tuya_iot_set_wf_gw_prod_info(&prod_info));
#else
// 产测初始化, 注册函数需要应用实现,其中串口驱动不需要应用提供
MF_IMPORT_INTF_S intf = {0};
intf.uart_init = mf_uart_init_callback;
intf.uart_free = mf_uart_free_callback;
intf.uart_send = mf_uart_send_callback;
intf.uart_recv = mf_uart_recv_callback;
intf.mf_user_product_test = mf_user_product_test_callback;
intf.user_callback = mf_user_callback;
intf.user_enter_mf_callback = mf_user_enter_mf_callback;
TAL_PR_ERR("mf_init APP_BIN_NAME[%s] USER_SW_VER[%s]", APP_BIN_NAME, USER_SW_VER);
TUYA_CALL_ERR_RETURN(mf_init(&intf, APP_BIN_NAME, USER_SW_VER, TRUE));
#endif
/* Initialize TuyaOS product information */
TY_IOT_CBS_S iot_cbs = {0};
iot_cbs.gw_status_cb = __soc_dev_status_changed_cb;
iot_cbs.gw_ug_cb = __soc_dev_rev_upgrade_info_cb;
iot_cbs.gw_reset_cb = __soc_dev_restart_req_cb;
iot_cbs.dev_obj_dp_cb = __soc_dev_obj_dp_cmd_cb;
iot_cbs.dev_raw_dp_cb = __soc_dev_raw_dp_cmd_cb;
iot_cbs.dev_dp_query_cb = __soc_dev_dp_query_cb;
TUYA_CALL_ERR_RETURN(tuya_iot_wf_soc_dev_init(GWCM_OLD, WF_START_AP_FIRST, &iot_cbs, PID, USER_SW_VER));
TUYA_CALL_ERR_RETURN(tuya_iot_reg_get_wf_nw_stat_cb(__soc_dev_net_status_cb));
/* Network button, LED initialization */
app_led_init(LED_PIN);
app_key_init(KEY_PIN);
hw_output_init();
ble_remote_init();
return 0;
以上代码在tuyaos_demo_quickstart工程中运行。
在开启绑定窗口内(可通过tuya_ble_set_bind_window() 设置)可以接收到数据,可以通过 tuya_ble_open_bind_window();再次开启。
chenyisong 2023年 Nov 20日 19:32我在BK7231N上测试了这个功能是可以正常接收到数据的,测试代码如下:
#include "tuya_bt.h" VOID ble_raw_scan(TAL_BLE_ADV_REPORT_T *scan_info) { TAL_PR_DEBUG("rssi:%d", scan_info->rssi); for (uint32_t i = 0; i < scan_info->data_len; i ++) { TAL_PR_DEBUG_RAW("%02x ", scan_info->p_data[i]); } TAL_PR_DEBUG_RAW("\r\n"); } /** * @brief * * @param[in] data: data * @param[in] len: data len * @param[in] type: type * @param[in] mac: device mac * @return none */ STATIC VOID ble_receive_callback(UCHAR_T *data, UCHAR_T len, UCHAR_T type, UCHAR_T* mac) { INT_T i = 0; TAL_PR_DEBUG_RAW("ble_receive_callback: "); for (uint32_t t = 0; t < len; t ++) { TAL_PR_DEBUG_RAW("%02x ", data[t]); } TAL_PR_DEBUG_RAW("\r\n"); return; } /** * @brief ble scanf adv bind check callback * * @param[in] type: bind type for bluetooth remote controller * @param[in] data: data * @param[in] len: data len * @return OPRT_OK */ STATIC OPERATE_RET ble_scan_adv_bind_check_callback(TUYA_BLE_BIND_TYPE type, UCHAR_T *data, UCHAR_T len) { INT_T i = 0; TAL_PR_DEBUG("----------------scan adv bind check cb-----------------"); TAL_PR_DEBUG("ble bind type : %d, data len: %d", type, len); for(i=0;i<len;i++) { TAL_PR_DEBUG("data[%d] : %d", i, data[i]); } return OPRT_OK; } /** * @brief ble scan adv bind notify callback * * @param[in] type: bind type for bluetooth remote controller * @return none */ STATIC VOID_T ble_adv_scan_bind_notify_callback(TUYA_BLE_BIND_TYPE type, int rslt) { TAL_PR_DEBUG("------------------ble scan adv bind notify cb----------------"); TAL_PR_DEBUG("ble bind type : %s", (type == TUYA_BLE_OP_BIND) ? "bind" : "unbind"); TAL_PR_DEBUG("result : %s", (rslt == 0) ? "success" : "failed"); return ; } /** * @brief ffc task * * @param[in] param:Task parameters * @return none */ VOID ble_remote_init(VOID) { OPERATE_RET rt = OPRT_OK; TUYA_BLE_SCAN_ADV_HANDLE_CBS ble_scan_cfg = {0}; ble_scan_cfg.bind_check = ble_scan_adv_bind_check_callback; ble_scan_cfg.bind_notify = ble_adv_scan_bind_notify_callback; /* Register callback function for advertisement scanning data processing */ TUYA_CALL_ERR_GOTO(tuya_ble_reg_app_scan_adv_cb(ble_receive_callback), __EXIT); /* Register callback function for advertisement scanning data processing */ TUYA_CALL_ERR_GOTO(tuya_ble_reg_app_scan_adv_handle_cbs(&ble_scan_cfg), __EXIT); /* Register callback function for advertisement scanning data processing */ TUYA_CALL_ERR_GOTO(tuya_ble_reg_raw_scan_adv_cb(ble_raw_scan), __EXIT); /* set bind window (s) */ tuya_ble_set_bind_window(30); __EXIT: return; } /** * @brief SOC device initialization * * @param[in] none * * @return OPRT_OK on success. Others on error, please refer to "tuya_error_code.h". */ OPERATE_RET __soc_device_init(VOID_T) { OPERATE_RET rt = OPRT_OK; #if (defined(UUID) && defined(AUTHKEY)) ws_db_init_mf(); /* Set authorization information * Note that if you use the default authorization information of the code, there may be problems of multiple users and conflicts, * so try to use all the authorizations purchased from the tuya iot platform. * Buying guide: https://developer.tuya.com/cn/docs/iot/lisence-management?id=Kb4qlem97idl0. * You can also apply for two authorization codes for free in the five-step hardware development stage of the Tuya IoT platform. * Authorization information can also be written through the production testing tool. * When the production testing function is started and the authorization is burned with the Tuya Cloud module tool, * please comment out this piece of code. */ WF_GW_PROD_INFO_S prod_info = {UUID, AUTHKEY}; TUYA_CALL_ERR_RETURN(tuya_iot_set_wf_gw_prod_info(&prod_info)); #else // 产测初始化, 注册函数需要应用实现,其中串口驱动不需要应用提供 MF_IMPORT_INTF_S intf = {0}; intf.uart_init = mf_uart_init_callback; intf.uart_free = mf_uart_free_callback; intf.uart_send = mf_uart_send_callback; intf.uart_recv = mf_uart_recv_callback; intf.mf_user_product_test = mf_user_product_test_callback; intf.user_callback = mf_user_callback; intf.user_enter_mf_callback = mf_user_enter_mf_callback; TAL_PR_ERR("mf_init APP_BIN_NAME[%s] USER_SW_VER[%s]", APP_BIN_NAME, USER_SW_VER); TUYA_CALL_ERR_RETURN(mf_init(&intf, APP_BIN_NAME, USER_SW_VER, TRUE)); #endif /* Initialize TuyaOS product information */ TY_IOT_CBS_S iot_cbs = {0}; iot_cbs.gw_status_cb = __soc_dev_status_changed_cb; iot_cbs.gw_ug_cb = __soc_dev_rev_upgrade_info_cb; iot_cbs.gw_reset_cb = __soc_dev_restart_req_cb; iot_cbs.dev_obj_dp_cb = __soc_dev_obj_dp_cmd_cb; iot_cbs.dev_raw_dp_cb = __soc_dev_raw_dp_cmd_cb; iot_cbs.dev_dp_query_cb = __soc_dev_dp_query_cb; TUYA_CALL_ERR_RETURN(tuya_iot_wf_soc_dev_init(GWCM_OLD, WF_START_AP_FIRST, &iot_cbs, PID, USER_SW_VER)); TUYA_CALL_ERR_RETURN(tuya_iot_reg_get_wf_nw_stat_cb(__soc_dev_net_status_cb)); /* Network button, LED initialization */ app_led_init(LED_PIN); app_key_init(KEY_PIN); hw_output_init(); ble_remote_init(); return 0; }
我按您的要求把代码复制过去,也添加了open_bind函数,可是还是看不到数据呢,手机用蓝牙工具APP能看到。您看下是哪里出的问题(补充下,遥控的数据目前只在广播的38信道发送数据)
1)tuya_ble_set_bind_window(0)后再open,可以永久打开时间窗
2)用NRF查看下是否能扫到你的beacon包,是否符合标准
bamy 2023年 Nov 21日 12:021)tuya_ble_set_bind_window(0)后再open,可以永久打开时间窗
应该符合什么样的标准呢?以前老的tuyaos用“esp_hal_ble_gap_set_event_cb()”注册回调后能能在“case ESP_GAP_BLE_SCAN_RESULT_EVT:”里面收到数据的。遥控数据的NRF接收如下图
或者有其他接口能接收蓝牙广播数据吗?
改了 ,还是不行
需要把GeneralDiscoverable 这个加上。目前除这三种的广播类型ADV_IND,SCAN_RSP,NONCONN_IND 的类型之外,其他类型都会过滤掉。
hearge 2023年 Nov 22日 14:34需要把GeneralDiscoverable 这个加上。目前除这三种的广播类型ADV_IND,SCAN_RSP,NONCONN_IND 的类型之外,其他类型都会过滤掉。
“广播类型ADV_IND,SCAN_RSP,NONCONN_IND ”是指截图中 目前“Legacy”这个类型吗
