[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:4
[11;28;45][PLATFORM ERROR]tuya_hal_adc_value_get ddev_open error:-5
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:5
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:6
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:7
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:8
【求助】iotos运行一段时间,adc报错
- V0.6.2_com3_[2022-10-18_11;28;43].log.zip
- (1.6 KiB) Downloaded 466 times
Re: iotos运行一段时间,adc报错
报错信息为
SDK版本:ty_iot_sdk_bk7231n-2.3.3
tuya_adc_t *adc ;
THREAD_HANDLE thread_ntc_temp_sampling_handle = NULL;//温度采样线程
static NTC_SENSOR *ntc_sensor; //定义传感器指针变量
- @Function: void adc_init
- @Description: 初始化adc io
- @Output: none
- @Return: none
- @Others: 无
void adc_init(void)
adc= (tuya_adc_t *)tuya_driver_find(TUYA_DRV_ADC, TUYA_ADC2);
if (NULL == adc) {
PR_ERR("tuya hal find failed");
return;
TUYA_ADC_CFG(adc, TUYA_ADC2, 0);
tuya_adc_init(adc);//ADC初始化
@brief thread_ntc_arry_func
线程调用函数
@param[in] none
@return none
@output
void thread_ntc_temp_sampling_func(void){
adc_init();
for (;;) {
set_ntc_temp_param();//设置ntc温度参数值
}// PR_NOTICE("thread ntc task will release");
// op_ret = tuya_hal_thread_release(thread_ntc_temp_sampling_handle);//释放线程
// if (OPRT_OK != op_ret) {
// PR_ERR("release thread_ntc_temp_sampling_handle failed, err_num:%d", op_ret);
// return;
@brief thread_ntc_init
ntc线程
@param[in] none
@return none
void thread_ntc_init(NTC_SENSOR *ntc10)
OPERATE_RET op_ret = OPRT_OK;
ntc_sensor_int(ntc10);op_ret = tuya_hal_thread_create(&thread_ntc_temp_sampling_handle, "thread_ntc_temp_sampling", 2048, TRD_PRIO_4, thread_ntc_temp_sampling_func, NULL);
if (op_ret != OPRT_OK) {
PR_ERR("thread_ntc_temp_sampling_func task failed, err_num:%d", op_ret);
return;
部分代码如下,麻烦看一下。
beautifulzzzz
