【求助】iotos运行一段时间,adc报错
狂扇赵四那半拉好嘴
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:4
[11;28;45][PLATFORM ERROR]tuya_hal_adc_value_get ddev_open error:-5
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:5
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:6
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:7
[11;28;45][10-18 11:28:45 TUYA Notice][lr:0x585f3] [smdz_ntc_temp_control_fun]ntc_abnormal_count:8
V0.6.2_com3_[2022-10-18_11;28;43].log.zip
(1.6 KiB) Downloaded 483 times
狂扇赵四那半拉好嘴
Re: iotos运行一段时间,adc报错
报错信息为
狂扇赵四那半拉好嘴
SDK版本:ty_iot_sdk_bk7231n-2.3.3
狂扇赵四那半拉好嘴
tuya_adc_t *adc ;
THREAD_HANDLE thread_ntc_temp_sampling_handle = NULL;//温度采样线程
static NTC_SENSOR *ntc_sensor; //定义传感器指针变量
  • @Function: void adc_init
  • @Description: 初始化adc io
  • @Output: none
  • @Return: none
  • @Others: 无
    void adc_init(void)
    adc= (tuya_adc_t *)tuya_driver_find(TUYA_DRV_ADC, TUYA_ADC2);
    if (NULL == adc) {
    PR_ERR("tuya hal find failed");
    return;
    TUYA_ADC_CFG(adc, TUYA_ADC2, 0);
    tuya_adc_init(adc);//ADC初始化
  • @brief thread_ntc_arry_func
  • 线程调用函数
  • @param[in] none
  • @return none
  • @output
    void thread_ntc_temp_sampling_func(void){
    adc_init();
    for (;;) {
    set_ntc_temp_param();//设置ntc温度参数值
    // PR_NOTICE("thread ntc task will release");
    // op_ret = tuya_hal_thread_release(thread_ntc_temp_sampling_handle);//释放线程
    // if (OPRT_OK != op_ret) {
    // PR_ERR("release thread_ntc_temp_sampling_handle failed, err_num:%d", op_ret);
    // return;
  • @brief thread_ntc_init
  • ntc线程
  • @param[in] none
  • @return none
    void thread_ntc_init(NTC_SENSOR *ntc10)
    OPERATE_RET op_ret = OPRT_OK;
    ntc_sensor_int(ntc10);
    op_ret = tuya_hal_thread_create(&thread_ntc_temp_sampling_handle, "thread_ntc_temp_sampling", 2048, TRD_PRIO_4, thread_ntc_temp_sampling_func, NULL);
    if (op_ret != OPRT_OK) {
    PR_ERR("thread_ntc_temp_sampling_func task failed, err_num:%d", op_ret);
    return;
部分代码如下,麻烦看一下。
beautifulzzzz
您好,请问您这边用的什么平台(芯片平台,用的哪个SDK)
创造传奇,不是卖艺! 8-)
