Generic Scene Switch
fangping.guo
Yes, I used your PID virtual device to conduct a simulation and capture the reported messages. On the Apple Home platform, I verified that single clicks, double clicks, and long presses could all be recognized.
Single Click
ReportDataMessage =
       SubscriptionId = 0xb37d7a9c,
       EventReportIBs =
               EventReportIB =
                       EventDataIB =
                               EventPath =
                                       Endpoint = 0x10,
                                       Cluster = 0x3b,
                                       Event = 0x1,
                           EventNumber = 0x00000000001D000E,
                           PriorityLevel = 0x0000000000000001,
                           SystemTimestamp = 0x00000000000189B3,
                           EventData =
                                   0x0 = 0 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x3,
                           EventNumber = 0x00000000001D000F,
                           DeltaSystemTimestamp = 0x0000000000000001,
                           EventData =
                                   0x0 = 0 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x6,
                           EventNumber = 0x00000000001D0010,
                           EventData =
                                   0x0 = 0 (signed),
                                   0x1 = 1 (signed),
   InteractionModelRevision = 11
Double Click
ReportDataMessage =
       EventReportIBs =
               EventReportIB =
                       EventDataIB =
                               EventPath =
                                       Endpoint = 0x10,
                                       Cluster = 0x3b,
                                       Event = 0x1,
                           EventNumber = 0x00000000001D0011,
                           SystemTimestamp = 0x0000000000031D9B,
                           EventData =
                                   0x0 = 0 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x3,
                           EventNumber = 0x00000000001D0012,
                           DeltaSystemTimestamp = 0x0000000000000002,
                           EventData =
                                   0x0 = 0 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x5,
                           EventNumber = 0x00000000001D0013,
                           EventData =
                                   0x0 = 0 (signed),
                                   0x1 = 2 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x3,
                           EventNumber = 0x00000000001D0014,
                           EventData =
                                   0x0 = 0 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x6,
                           EventNumber = 0x00000000001D0015,
                           EventData =
                                   0x0 = 0 (signed),
                                   0x1 = 2 (signed),
Long Press
ReportDataMessage =
       EventReportIBs =
               EventReportIB =
                       EventDataIB =
                               EventPath =
                                       Endpoint = 0x10,
                                       Cluster = 0x3b,
                                       Event = 0x2,
                           EventNumber = 0x00000000001D0016,
                           SystemTimestamp = 0x000000000003D740,
                           EventData =
                                   0x0 = 0 (signed),
           EventReportIB =
                   EventDataIB =
                           EventPath =
                                   Endpoint = 0x10,
                                   Cluster = 0x3b,
                                   Event = 0x4,
                           EventNumber = 0x00000000001D0017,
                           EventData =
                                   0x0 = 0 (signed),
Sugar
Re: Generic Scene Switch
Thank you for being so helpful. I appreciate it.
I will share further updates when Aqara responds.
fangping.guo
Thank you for your email. I have understood the difference between TUYA and Aqara when sending events.
I will try to modify the code to make it work properly.
But there is a question: if the value of the event is correct but only the type is wrong (reported as signed), will Aqara accept it?
Sugar
fangping.guo 2026年 Feb 11日 14:36
Hello :)
Long press is working with reported as signed, but they can't guarantee it will work with single or double press. They follow the matter documentation with their controllers, and in my opinion its not worth trying to make it work, because in future it could cause problems, for example, with Google, or any other matter platforms which will strictly follow matter documentation. It's better to make it as it should be and use it for all of the Tuya momentary switches, than later trying to fix it again, and change so much code for every single switch if it suddenly stops working somewhere due to a mismatch with Matter documentation.
Thank you.
Sugar
extra information:
GenericSwitchMultiPressComplete, PreviousPosition=0
Change that 0 to 1 and let's see if single press is working with reported as signed.
fangping.guo
Hello, I have updated the configuration file again (without changing the data type issue. I hope it can be made usable without modifying the firmware).
Could you please unbind and rebind it to test if it is working properly now?
Sugar
fangping.guo 2026年 Feb 24日 15:03
Did you update that single button?
If yes, I unbinded it, etc., but still only long press is working.
New virtual ID of that single button: bf4ba84a8ef6c9fba1ulqx
fangping.guo
yes. zone china, aqara device id 【matt.7c49d0b6147c6446d2816000】
Sugar
I will repeat unbind and bind again later. Which hub do you have for that screenshot? I have aqara m100.
fangping.guo
