A new device connected to the Moes Matter Hub cannot register with SmartSings.
shelee91
MOES Tuya Zigbee Matter
Virtual ID : s8fe60507e140013c666k1
Presence sensoor
Virtual ID : s8fdf7c2988cee4e341nkm
Thank you if possible to add it.
fangping.guo
Re: A new device connected to the Moes Matter Hub cannot register with SmartSings.
Hello, I can't find your device information. Are you using the Tuya App?
shelee91
It's not exactly a tuya app, it's a tuya-based app. It's an app called hejhome, is it impossible in this case?
fangping.guo
Sorry, I can only retrieve the device ID from the Tuya app.
shelee91
I reconect the devices in tuya app.
Recheck, Please. Thanks.
Virtual ID : ebf1ee2625e5fb3f815lww
Presence sensoor
Virtual ID : eb22baf627d92e08cfxxiw
shelee91
I updated new topic like below,
Please check this issue.
shelee91 2026年 Feb 2日 22:54
Presence sensoor
fangping.guo
Hello, the device is now capable of bridging. Please restart the Matter gateway to verify.
shelee91
I checked. The device has been handed over to Bridging. However, it's a wired product, and the battery information is 1% and the current status continues to be in the room. It's the same for restarting the Matter Hub, SmartThings Hub.
fangping.guo
I disabled the battery function. You can restart the gateway to verify. What do you mean by "the current status remains in the room"?
shelee91
It meant that the detection status was only "presence".
After your action, the battery display still comes out at 1%, but the detection sratus is bridging well.
If there is nothing more to do about battery display, it will work well as it is, so there will be no problem.
Do you have another action about battery display issue?
