Generic Temperature and humidity sensor
Sugar
Hi, if you can expose that temperature and humidity sensor:
Virtual ID of that sensor:
bf118a868a72f10be5g134
Virtual ID of the hub:
bf01ab90188976b3f7xqtl
Thank you.
fangping.guo
Re: Generic Temperature and humidity sensor
Hello, I have added bridge support for this temperature and humidity meter. You can restart your Matter gateway to verify it.
Sugar
Thanks, it's working.
Sugar
fangping.guo 2026年 Jan 12日 09:43
It's keeping reporting battery status as 2%, I think its beacuse in tuya app, battery level status is high, normal, and low. So I think it's better just turn off battery status in Matter, or make that high is reported as 100%, normal as 50%, and low maybe as 10%.
Battery Status In Aqara App:
Battery Status In Tuya App:
Virtual ID: bf118a868a72f10be5g134
Thanks.
fangping.guo
It has been updated. You need to unbind it and (ideally restart the gateway) rebind it to trigger the change.
Sugar
It's now 0 percent:
But if it can't be fixed, then it's ok, it's better than 2 percent hah, and no big problem.
Thank you.
fangping.guo
It has been updated [again]. You need to unbind it and (ideally restart the gateway) rebind it to trigger the change.
Sugar
fangping.guo 2026年 Feb 24日 09:28
Thanks, wokring as intended.
