Tuya Zigbee Devices not Published on Matter properly
Hollako
Hello Dears,
First many thanks for your supports, now i can see many keypads are working with Matter however still some others not working, i will list below the status of each one:
M8-2: 2 Switches can be configured as scenes: Done
M8-3: 3 Switches can be configured as scenes: Done
M8-6: bf7a201d7ab996a3c1irth (4 Switches can be configured as scenes and 2 dedicated scenes): Done, but showing 6 relays on Matter however this keypad has 4 relays not 6
Knob Dimmer: bf15fb38bb7edd3a52j0fw (2 Switches can be configured as scenes + Knob Dimmer Control): Working from Smart Life App but Not showing on Matter at all
M8-Pro: 4 Switches can be configured as scenes with small LCD: Done
LCD Panel: bf0cb6aa50ac0aafddrttv (4 Switches can be configured as scene with Display Screen): Not working on Smartlife App now, i can only see feedback from Switch but from the App i can't control it, Note that it's showing on Matter but not working, only i can see feedback.
M9-Pro: bf04907a3aab3cd0c0rqer (4 Switches can be configured as scenes and 4 dedicated scenes): Not working on Smartlife App now, i can only see feedback from Switch but from the App i can't control it, Note that it's showing on Matter but not working, only i can see feedback.
M9 LCD Keypad: bf9100d144d694f8a8laf6 (4 Switches can be configured as scenes with LCD): Working from Smart Life App but Not Showing on Matter At All
Regards,
fangping.guo
Re: Tuya Zigbee Devices not Published on Matter properly
I have modified the product configuration as below, please test again, thank you!
Hollako
Hello Dear,
Here is the latest status after checking on the non-working devices. first i can say that everything is working on Smart Life app again. however still on Matter not working properly:
M8-6: bf7a201d7ab996a3c1irth, Done
Knob Dimmer: bf15fb38bb7edd3a52j0fw, Showing on Matter as 2GangSwitchAndScene but not working.
LCD Panel: bf0cb6aa50ac0aafddrttv, Showing as 4SwitchAnd8Scene but not working, what i noticed is when i press the button on the keypad configured as relay it will trigger the scene on Matter. But i am not able to control the Relay switch or get the feedback.
M9-Pro: bf04907a3aab3cd0c0rqer, Showing as 4SwitchAnd8Scene but not working, what i noticed is when i press the button on the keypad configured as relay it will trigger the scene on Matter. But i am not able to control the Relay switch or get the feedback.
M9 LCD Keypad: bf9100d144d694f8a8laf6, Showing as 4SwitchAnd8Scene but not working, what i noticed is when i press button on the keypad configured as relay it will trigger the scene on Matter. But i am not able to control the Relay switch or get the feedback.
fangping.guo
I fixed those wrong configurations, please test again, thank you!
Hollako
Hello Dears,
Now all the Relays are showing to Home Assistant, many thanks for yoru support.
However, just to make things better i have 3 things i want to make sure if this is possible.
1- Knob Dimmer Switch is only showing On/Off however this includes Level Brightness and White Color Temperature (Kelvin) so how much is possible to add the dimmer and White Color Temperature to Matter?
2- The names of the Relays are not reflected on Matter, for example if i name a Relay "Living Room" in Smart Life App, i don't see that on Matter. So in a big project i need to re-test all the lights and rename them in Home Assistant.
3- When a device goes Offline in Smart Life App i don't see it Offline on Matter, is it also possible to know the lights if it's offline on Matter as well?
Regards and Thanks again for your great support.
fangping.guo
  1. I updated the configuration file for the Knob Dimmer Switch, which should now display as one CW light, two Generic switches, and two OnOff switches.
  2. Yes, currently, the device names in Tuya will not be synchronized to the Matter ecosystem. Instead, the device names are fixed in the configuration file, which is indeed inconvenient.
  3. I think that when the device is offline in the Tuya app, it will automatically show as unresponsive in the Matter ecosystem. Can you wait a few more minutes to confirm that there really is no change?
Hollako
Hello Dear,
Well noted regarding the replies you mentioned.
For the Knob Dimmer, actually now it's showing as ad Dimmer light, but i have 2 issues not working:
1- It only show the a Dimmable light but not CW light, so there is no option to chnage the White Color.
2- Even the dimmer light is not working in 2 way. Means from Home home Assistant i am not able to send a command to the dimmer, only if i change the value in the Knob i can see the feedback in Home Assistant.
And i have another question regading all the keypads they are already working, all these keypads relays are shown in Home Assistant as a Switch and not Light, knowing that i can convert them as Lights in Home Assistant. But there is no possibility that these keypad relay shows direclty as lights in Home Assistant to make things faster and more simple ?
Thank you in advance.
fangping.guo
  1. From the configuration file, I see that I have configured the device as a CW light. Have you tried unpairing the device and retesting? If there is still no change, I would like to check your gateway log. Would you mind providing your gateway ID again?
  2. Sorry, according to the current design, the switch is just an On/Off switch, not a light switch.
Hollako
Hello Dear,
Sorry for the late reply, here is the Gateway ID (Zemismart M6 Hub): bfa5f0c5f7938bb88abam5
Regards
fangping.guo
Hello.
I don't see any major issues based on the gateway log. Could you try operating the dimmer switch device using the Tuya app and Apple Home, and let me know the approximate time you operated it?
For example, use the Tuya app to set the light switch, brightness, and color temperature at 08:00, and use the Apple Home app to set the light switch at 08:30. In addition, it would be great if you could provide a screenshot or video of the device display in Apple Home.
Thank you for your cooperation.
