Smartthings & Moes Matter MZHUB troubleshooting - *ISSUE SOLVED*
poulmadsen
Hi Tuya forum
I was directed to this forum from the smartthings community, as I'm having some issues after integrating Moes Matter hub into my Smartthings setup. I hope you can help me get this issue fixed or point me in the right direction what I can do to make it work.
The situation:
I’m having a 2018 Smartthings Hub firmware version 000.057.00014 and a Moes Matter Zigbee MZHUB Main module v1.12.6, Other type v.3.7.2.
Smarthings and Moes hubs are connected via Matter and I have 4 Tuya Zigbee devices connected to the Moes hub.
1 Temp and humidity sensor
1 Human presence sensor
2 soil sensors.
The issue is that I can’t get the devices to be presented in a useful way in Smarrthings. After the matter integration, the devices are listed a “Matter switch” or “Matter Device” with no updates. I have tried to remove and repair, reboot the hubs after each step and removing and adding 1by1 but no success to get any update.
The only thing I managed to get working is to manually change the type to “Matter Thing” and the presence sensor is now updating, but very very limited companied to the information in the Moes app. The other devices had 1 update (when changed to “Matter Thing”) and no update since.
Kind regards
Poul
Sergitovall
Re: Smartthings & Moes Matter MZHUB troubleshooting - help needed
Same problem here
huangxh
poulmadsen 2025年 Jun 23日 22:31
Hi Tuya forum
The situation:
2 soil sensors.
Kind regards
Poul
Pls send the device id of gateway to me.thanks.
poulmadsen
Thank you so much for the reply. You should have a private message with the information from me.
Kind regards
Poul
huangxh 2025年 Jun 24日 09:49
Hi Tuya forum
The situation:
2 soil sensors.
Kind regards
Poul
poulmadsen
Hi @huangxh
Could you please let me know if you got my information as requesed?
Thanks
Poul
Hi Tuya forum
The situation:
2 soil sensors.
Kind regards
Poul
huangxh
poulmadsen 2025年 Jun 27日 18:44
Hi @huangxh
Thanks
Poul
Hi Tuya forum
The situation:
2 soil sensors.
Kind regards
Poul
Please provide the device ID of the gateway. I will update it to version 1.13.8. Then delete those sensors and add them again. Thank you.
poulmadsen
Hi again
I have tried to forward the requested information by private messages, I'm not sure if you are able to get those messages from me? Are there any other way I can forward that information to you?
Appreciate your help and looking forward to the 1.13.8 update.
Thanks
Poul
huangxh 2025年 Jun 28日 11:40
Hi @huangxh
Thanks
Poul
fangping.guo
Hi, we have added your gateway id to the list of upgraded version 1.13.8.
Please check the push message and do the device update, then unbind and retry. Your feedback is welcome.
poulmadsen
fangping.guo 2025年 Jul 9日 15:22
@fangping.guo
Thank you thank you thank you. The hub is now updated to 1.13.8 and there is a improvement with one of the sensors. After the update, I have removed all devices and the Matter connection between Moes Hub and Smartthings and reconnected it again. Both Hub's are also rebooted.
Feedback: I have 4 sensors, 1 is now working as expected (the Occupancysensor), 2 are just added as temperature humidity and not updating any value, and 1 is not visible to Smartthings at all.
Please see attachments with screenshot of versions and let me know any action I need to perform.
Thanks
Poul
fangping.guo
Hi Poul, thanks for the feedback!
In order to troubleshoot the temp and humidity sensor and soil sensors, I need to get the ids of these devices. these ids are available in the device details page of the tuya smart app, please provide me with their data so that I can analyze it, thanks!
Ref:How do I view the id/ip/mac address/time zone of a device?
