Store matter compatible devices automation locally
Vamp
In the future, will this possible that matter/thread compatible wifi devices related automation are stored locally , similarly with Local/LAN linkage on Zigbee gateways?
For example, if i have a Tuya matter gateway (THP10-Z-X) and connect it to a wifi matter device , i able to make a automation than store it in the Tuya matter hub? (like it work with zigbee devices currently)
huangxh
Re: Store matter compatible devices automation locally
Vamp 2024年 Dec 16日 03:58
Hi Vamp:
we have supported this function, you can test it now.thank you.
Vamp
@huangxh
That meen if a buy a matter compatible wifi tuya device, for example these one: https://www.tuyaexpo.com/product/1141020
and create a automation , it automatically convert it to local/lan linkage?
huangxh
Vamp 2024年 Dec 16日 21:06
@huangxh
Here are several scenarios (with a Matter hub):
If the Wi-Fi device is a third-party Matter over Wi-Fi device, the automation is local.
If it is a Tuya Matter over Wi-Fi device and this device supports LAN linkage, then automation can be stored locally on the gateway.
As for whether this Wi-Fi device supports LAN linkage, you can consult the corresponding device's vendor.
Thank you!
Vamp
We are tested it and yes, it working well! Thanks for the information!
