ECR6600 低功耗一些问题
hzb
见附件
hzb
Re: ECR6600 低功耗一些问题
抓取部分编译错误信息:
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(uni_network.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(mqc_app.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(wpa_supplicant.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(driver_tuya.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_wpa_supp.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_hostap.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_wlan_auth.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_ble_dp.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_ble_active.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_ble_sdk.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_svc_upgrade.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(mem.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(timeouts.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(raw.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(ip4_frag.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(ip4.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(dhcp.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tcp_in.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(api_lib.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(netdb.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(sockets.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(lwip_dhcpc.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_devos.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_devos_stride.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(wifi_netcfg_frame_sniffer.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_wifi_connect.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(wf_protect.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tal_thread.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tal_log.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos.a(tuya_lan_sock.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: /home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/libs/libtuyaos_adapter.a(tkl_ota.c.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: build/tuyaos_demo_application_driver/libs/libcomponents.a(system_config.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(llm.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(rwip.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(uart_adapt.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(vif_mgmt.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(mm_bcn.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(me_task.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(sm.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(scanu.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(hsu.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(fhost_cntrl.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-fflush.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-findfp.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-fstatr.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-nano-mallocr.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-sbrkr.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-vsnprintf.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-w_pow.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-writer.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-closer.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-isattyr.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-lseekr.o): warning: _FP_BASE_ setting insns relaxation failed.
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-readr.o): warning: _FP_BASE_ setting insns relaxation failed.
Makefile:208: recipe for target 'build/tuyaos_demo_application_driver/tuyaos_demo_application_driver.elf' failed
make[3]: *** [build/tuyaos_demo_application_driver/tuyaos_demo_application_driver.elf] Error 1
make[3]: Leaving directory '/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os'
Makefile:115: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os'
makefile:9: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards/ecr6600/tuya'
/home/hzb/workspace/tuya/ECR6600-TS2D_TuyaOS-3.5.7/software/TuyaOS/scripts/mk/app.mk:186: recipe for target 'app_by_name' failed
make: *** [app_by_name] Error 2
hzb
Re: ECR6600 低功耗一些问题
抓取部分错误信息,具体你可以自行尝试编译下:
yingtao_33
Re: ECR6600 低功耗一些问题
快速上手demo 已经更新了。你可以下载 tuyaos_demo_quickstart 2.0.4 版本
hzb
Re: ECR6600 低功耗一些问题
好的,已下载验证可以了,并且进入低功耗模式也正常了。
另外请教下:
进入deep sleep模式后,配置io唤醒,通过按键触发唤醒后,模组重启了, 看日志打印的时间戳,从重启到应用按键初始化(在__soc_device_init中调用app_key_init进行按键初始化)大概需要1.5秒, 有什么办法能加快按键初始化,快速响应按键处理嘛? 不然用户短按至少长按1.5秒以上才能处理被捕捉到。
JSHANG
Re: ECR6600 低功耗一些问题
将app_key_init提前,放到这个函数最前面
Re: ECR6600 低功耗一些问题
hzb 2024年 Apr 22日 23:21
另外请教下:
hi,上报时间太长的问题,能提供一个完整的唤醒到谁上报成功的log么?
hzb
Re: ECR6600 低功耗一些问题
日志详见附件SaveWindows2024_5_7_20-19-40.TXT
(44.02 KiB) Downloaded 517 times
Re: ECR6600 低功耗一些问题
更新到3.5.8版本试试。
