T3_3.12.0编译失败
a93749
求助,T3tuyaos-3.12.0版本编译失败,前两天没有问题的,我还尝试了3.11.24版本,3.11.24编译能过.3.12.0编译失败的日志在附件(1.txt)里,今天编译的时候好像是ide编译过程中好像是python的什么东西更新了 我没记录,后面发现编译失败回头看来发现记录已经找不到了.
管道直接导出的日志有问题 少了以下部分,
make[1]: Entering directory '/home/gd/Documents/tuya/Projects/T3_TuyaOS-3.12.0/software/TuyaOS/vendor/T3/t3_os/armino'
Parsing CSV input to gen part table...
Remap part table, convert logic addr to phy addr...
Gen partition_bk7256_ota_a_new.json using remapped part table...
Setting ARMINO_PATH environment variable: /home/gd/Documents/tuya/Projects/T3_TuyaOS-3.12.0/software/TuyaOS/vendor/T3/t3_os/armino
pkg_resources cannot be imported probably because the pip package is not installed and/or using a legacy Python interpreter. Please refer to the Get Started section of the BEKEN-ARMINO Programming Guide for setting up the required packages.
fatal: not a git repository: '/home/gd/Documents/tuya/Projects/T3_TuyaOS-3.12.0/software/TuyaOS/vendor/T3/t3_os/armino/.git'
WARNING: Git version unavailable, reading from source
WARNING: Cannot find BEKEN-ARMINO version in version.cmake
BEKEN-ARMINO version unknown
make[1]: *** [Makefile:136: bk7236] Error 1
make[1]: Leaving directory '/home/gd/Documents/tuya/Projects/T3_TuyaOS-3.12.0/software/TuyaOS/vendor/T3/t3_os/armino'
make failed
build.sh: 245: exit: Illegal number: -1
make: *** [/home/gd/Documents/tuya/Projects/T3_TuyaOS-3.12.0/software/TuyaOS/scripts/mk/app.mk:195: app_by_name] Error 2
1.txt
3.12.0编译失败日志
(13.35 KiB) Downloaded 149 times
a93749
Re: T3_3.12.0编译失败
已解决,将虚拟python环境中的setuptools>=72.2.0改为setuptools==69.5.1
具体路径为software/TuyaOS/vendor/T3/t3_os文件夹下的requirements.txt中,具体原因应为setuptools82版本删除了pkg_resources,降级该虚拟环境中的这个setuptools就行
