The dimmer function is not working correctly.
unnamedi
Hello, I have some dimmer devices that are not working correctly via matter.
They are not working at all, whether in SmartThings, Home Assistant, or Google Home.
And another one, a single-channel dimmer, is being exported as a dual-channel dimmer!
This is a 1-channel dimmer device that appears as two channels no matter what.
Virtual ID: ebb9954fb961cd649avood
This is a 2-channel dimmer that is not working correctly at the percentage of platforms I mentioned!
Virtual ID: eb6885b967cda3fdfcakgp
This is a 1-channel dimmer that is not functioning correctly with the % function on all platforms.
Virtual ID: eb35685daab86c2f14ecmm
fangping.guo
Re: The dimmer function is not working correctly.
Hello, I have fixed the issues with ebb9954fb961cd649avood and eb35685daab86c2f14ecmm. You can restart the gateway, wait a few minutes, and then verify if they are working.
Regarding the issue you mentioned with eb6885b967cda3fdfcakgp, please provide specific details. For example, which features are not working on which platforms, and what the expected and actual results are respectively.
