TLSR8258 SDK 如何主动采集电量
梁修道
使用tuya-zigbee-sdk-tlsr8258,其中sensor例程里电量是周期性自动采集的,如何变成手动采集?
即有一个函数,主动调用后开始采集,采集完成通知回调来处理数据上报
huanghuan
Re: TLSR8258 SDK 如何主动采集电量
您可以参考以下方式:
1.sdk在进行周期上报电量前会通过回调
bool_t dev_report_battery_by_user_data(dev_send_data_t OUT *send_data, uint8_t percentage, uint8_t voltage)
函数告知应用上报的数据信息,应用可以再该函数内自己采样并修改send data数据来实现上报数据的替换,您可以参考以下例程进行滤波等策略
    const battery_table_t table[] = {BATTERY_USER_TABLE};
    const uint8_t table_num = sizeof(table)/sizeof(battery_table_t);
const uint8_t t_msg_len = 10;/*数据长度*/ uint16_t t_voltage_average = 0; uint8_t i = 0; uint8_t t_dp = 0; uint8_t *data = NULL; t_voltage_average = average_filter_get_voltage_value(); if(table_num>1) { if(t_voltage_average < table[0].voltage) { percentage = 0; } else if (t_voltage_average >= table[table_num-1].voltage) { percentage = 100; } else { for(i = 0;i<table_num-1;i++) { if((t_voltage_average>=table[i].voltage) && (t_voltage_average<table[i+1].voltage)) { percentage = table[i].percent + \ ((t_voltage_average-table[i].voltage)*(table[i+1].percent-table[i].percent))/(table[i+1].voltage-table[i].voltage); break; } } } } if(0xFFFF == g_private_report_str.sequence_num) { g_private_report_str.sequence_num = 0; } else { g_private_report_str.sequence_num ++; } data = malloc(t_msg_len*sizeof(uint8_t)); if(data) { memset(data,0x00,t_msg_len); data[0] = (uint8_t)(g_private_report_str.sequence_num>>8); data[1] = (uint8_t)(g_private_report_str.sequence_num); data[2] = BATTERY_VALUE_DP; data[3] = TYPE_VALUE; data[4] = 0; data[5] = 0x04; data[6] = 0; data[7] = 0; data[8] = 0; data[9] = percentage; memset(send_data, 0, sizeof(dev_send_data_t)); send_data->zcl_id = 0;//++zcl_seq; send_data->qos = QOS_1; send_data->commmand_type = ZCL_COMMAND_CLUSTER_SPEC_CMD; send_data->direction = ZCL_DATA_DIRECTION_SERVER_TO_CLIENT; send_data->command_id = TY_MODULE_DATA_REPORT_CMD; send_data->addr.mode = SEND_MODE_GW; send_data->addr.type.gw.cluster_id = CLUSTER_PRIVATE_TUYA_CLUSTER_ID; send_data->addr.type.gw.src_ep = 1; send_data->delay_time = 0; send_data->random_time = 0; send_data->data.private.len = t_msg_len; memcpy((send_data->data.private.data),data,t_msg_len); free(data); } return TRUE; }
huanghuan
 * @description: 平均值滤波读取电源电压
 * @param {type} none
 * @return: none
uint16_t average_filter_get_voltage_value(void)
    uint16_t t_voltage_sum = 0;
    uint16_t t_compare_num = 0;
    uint16_t t_voltage[BATTERY_ALARM_FILTER_TIMES] = {0};
    t_compare_num = BATTERY_ALARM_FILTER_TIMES;
    memset(t_voltage,0x00,sizeof(uint16_t )*BATTERY_ALARM_FILTER_TIMES);
for(uint8_t i = 0; i < BATTERY_ALARM_FILTER_TIMES; i ++)/*平均值滤波*/ { t_voltage[i] = hal_adc_to_voltage(hal_adc_get_value()); t_voltage_sum += t_voltage[i]; } t_voltage_average = t_voltage_sum/BATTERY_ALARM_FILTER_TIMES; t_voltage_sum = 0; for(uint8_t i = 0; i < BATTERY_ALARM_FILTER_TIMES; i ++) { if((t_voltage[i]>(t_voltage_average+BATTERY_ALARM_FILTER_OFFSET)) ||((t_voltage[i]+BATTERY_ALARM_FILTER_OFFSET)<t_voltage_average)) { t_compare_num --; } else { t_voltage_sum += t_voltage[i]; } } if(t_compare_num)/*除数不能为零,为零则保留原有平均值*/ { t_voltage_average = t_voltage_sum/t_compare_num; } return t_voltage_average; }
huanghuan
2.若您需要单独开启采集任务并进行数据上报,可以通过应用开启定时器,并通过 hal_adc_to_voltage();hal_adc_get_value();相关函数进行采样,并通过dev_zigbee_send_data 函数自己进行采样数据上报。相关数据转载可以查看方法1进行参考使用
梁修道
感谢 我试一下
