T2编译错误
Jimny
使用T2模块,搭建好编译环境,编译tyo时报错,请问怎么解决?
make: *** [scripts/mk/xmake.mk:220: /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/output/t2_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/tuya_app_main.c.o] Error 1
Re: T2编译错误
需要完整的编译log,这一点看不出来。
Jimny
Re: T2编译错误
cd '/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/'
export TUYA_IDE_PYTHON_ENV=/home/q/.tuya/venv/bin/python
q@q-VirtualBox:~/Documents/tuya/Projects/T2_TuyaOS-3.3.4$ cd '/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/'
./build_app.sh apps/tuyaos_demo_quickstart tuyaos_demo_quickstart 1.0.0
q@q-VirtualBox:~/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS$ export TUYA_IDE_PYTHON_ENV=/home/q/.tuya/venv/bin/python
q@q-VirtualBox:~/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS$ cd '/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/'
q@q-VirtualBox:~/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS$ ./build_app.sh apps/tuyaos_demo_quickstart tuyaos_demo_quickstart 1.0.0
APP_PATH=apps/tuyaos_demo_quickstart
APP_NAME=tuyaos_demo_quickstart
APP_VERSION=1.0.0
USER_CMD=
APP_VERSION= 1.0.0
TARGET_PLATFORM= t2
File "./scripts/set_app_config.py", line 15, in <module>
from ruamel import yaml # pip3 install ruamel.yaml
ModuleNotFoundError: No module named 'ruamel'
./scripts/prepare_param.sh: line 7: git: command not found
grep: make.yaml: No such file or directory
toolchain Name: t2
toolchain Repo: https://airtake-public-data-1254153901. ... ct/t2_.zip
toolchain Version:
++++++++++++++++++++ CI package fullname ++++++++++++++++++++
++++++++++++++++++++ the SDK ID tuyaos_demo_quickstart_1.0.0_t2 ++++++++++++++++++++
generate build_param for [ tuyaos_demo_quickstart ] AT [ t2 ]
Project [ tuyaos_demo_quickstart ] Param:
BUILD_DATE=2025_08_18
BUILD_TIME=09_36_18
GIT_USER=
IOT_SDK_VER=1.0.0
IPC_SDK_VER=1.0.0
SDK_FULL_VER=1.0.0
SDK_BETA_VER=
IOT_SDK_VER_MAJOR=1
IOT_SDK_VER_MINOR=0
IOT_SDK_VER_PATCH=0
KERNEL_VERSION=
PROJECT_NAME=tuyaos_demo_quickstart
TARGET_PLATFORM=t2
TARGET_PLATFORM_REPO=https://airtake-public-data-1254153901. ... ct/t2_.zip
TARGET_PLATFORM_VERSION=
BUILD_STATIC=1
BUILD_SHARED=
SDK_ID=tuyaos_demo_quickstart_1.0.0_t2
ROOT_DIR=/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS
OUTPUT_DIR=$(ROOT_DIR)/output/$(TARGET_PLATFORM)_$(PROJECT_NAME)
OUTPUT_DIR_INC=$(OUTPUT_DIR)/include
OUTPUT_DIR_STATIC_LIB=$(OUTPUT_DIR)/static/lib
OUTPUT_DIR_SHARED_LIB=$(OUTPUT_DIR)/shared/lib
OUTPUT_DIR_STATIC_OBJS=$(OUTPUT_DIR)/static/objs
OUTPUT_DIR_SHARED_OBJS=$(OUTPUT_DIR)/shared/objs
COMPILE_PREX = /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos/../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-
TUYAOS_BUILD_PATH = /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos
AR = $(COMPILE_PREX)ar
CC = $(COMPILE_PREX)gcc
NM = $(COMPILE_PREX)nm
CPP = $(COMPILE_PREX)g++
STRIP = $(COMPILE_PREX)strip
OBJCOPY = $(COMPILE_PREX)objcopy
OBJDUMP = $(COMPILE_PREX)objdump
RANLIB = $(COMPILE_PREX)ranlib
CXX = $(COMPILE_PREX)g++
CFLAGS =
CFLAGS += -pipe -D_REENTRANT -Wall -Wno-unused-result
ifeq ($(CONFIG_OPERATING_SYSTEM), 100)
CFLAGS += -fPIC
endif
ifeq ($(CONFIG_TUYA_IOT_DEBUG), 1)
CFLAGS += -g
endif
ifdef PRJ_DEFINES
CFLAGS += $(PRJ_DEFINES)
endif
ifdef COMPILE_INCLUDE
CFLAGS += -I $(COMPILE_INCLUDE)
endif
ifdef COMPILE_LIB
export LD_LIBRARY_PATH=$(COMPILE_LIB)
endif
LINKFLAGS =
LINKFLAGS += -lpthread -lm
endif
ifdef PRJ_LINKS
LINKFLAGS += $(PRJ_LINKS)
endif
clean application static ...
find: ‘apps/tuyaos_demo_quickstart/application_components’: No such file or directory
find: ‘apps/tuyaos_demo_quickstart/application_drivers’: No such file or directory
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/dp_process.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tal_uart.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/app_key.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrencode.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/mmask.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/rsecc.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrinput.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrspec.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/mask.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/mqrspec.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/bitstream.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/split.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/app_led.c
CC /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c: In function 'mf_uart_init_callback':
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c:264:19: error: 'TUYA_UART_NUM_0' undeclared (first use in this function)
tal_uart_init(TUYA_UART_NUM_0, &cfg);
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c:264:19: note: each undeclared identifier is reported only once for each function it appears in
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c: In function 'mf_uart_free_callback':
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c:278:21: error: 'TUYA_UART_NUM_0' undeclared (first use in this function)
tal_uart_deinit(TUYA_UART_NUM_0);
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c: In function 'mf_uart_send_callback':
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c:292:20: error: 'TUYA_UART_NUM_0' undeclared (first use in this function)
tal_uart_write(TUYA_UART_NUM_0, data, len);
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c: In function 'mf_uart_recv_callback':
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c:306:26: error: 'TUYA_UART_NUM_0' undeclared (first use in this function)
return tal_uart_read(TUYA_UART_NUM_0, buf, len);
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c:307:1: warning: control reaches end of non-void function [-Wreturn-type]
compile command:
/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos/../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-gcc -pipe -D_REENTRANT -Wall -Wno-unused-result -I/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos//..//../../adapter/system/include -I/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos//..//../../adapter/system/include/driver -I/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos//..//../../adapter/system/include/system -I/home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/vendor/t2/tuyaos//..//../../adapter/utilities/include -g -mthumb -mcpu=arm968e-s -march=armv5te -mthumb-interwork -mlittle-endian -Os -std=c99 -ffunction-sections -Wall -fsigned-char -fdata-sections -Wunknown-pragmas -nostdlib -Wno-unused-function -Wno-unused-but-set-variable -Iapps/tuyaos_demo_quickstart/include -Iinclude -Iinclude/base -Iinclude/base/include -Iinclude/adapter -Iinclude/adapter/init -Iinclude/adapter/init/include -Iinclude/adapter/system -Iinclude/adapter/system/include -Iinclude/adapter/pwm -Iinclude/adapter/pwm/include -Iinclude/adapter/wired -Iinclude/adapter/wired/include -Iinclude/adapter/adc -Iinclude/adapter/adc/include -Iinclude/adapter/security -Iinclude/adapter/security/include -Iinclude/adapter/spi -Iinclude/adapter/spi/include -Iinclude/adapter/gpio -Iinclude/adapter/gpio/include -Iinclude/adapter/register -Iinclude/adapter/register/include -Iinclude/adapter/rtc -Iinclude/adapter/rtc/include -Iinclude/adapter/i2c -Iinclude/adapter/i2c/include -Iinclude/adapter/pinmux -Iinclude/adapter/pinmux/include -Iinclude/adapter/flash -Iinclude/adapter/flash/include -Iinclude/adapter/wifi -Iinclude/adapter/wifi/include -Iinclude/adapter/timer -Iinclude/adapter/timer/include -Iinclude/adapter/bluetooth -Iinclude/adapter/bluetooth/include -Iinclude/adapter/network -Iinclude/adapter/network/include -Iinclude/adapter/pm -Iinclude/adapter/pm/include -Iinclude/adapter/uart -Iinclude/adapter/uart/include -Iinclude/adapter/i2s -Iinclude/adapter/i2s/include -Iinclude/adapter/dac -Iinclude/adapter/dac/include -Iinclude/adapter/hci -Iinclude/adapter/hci/include -Iinclude/adapter/watchdog -Iinclude/adapter/watchdog/include -Iinclude/adapter/utilities -Iinclude/adapter/utilities/include -Iinclude/components -Iinclude/components/svc_devos -Iinclude/components/svc_devos/include -Iinclude/components/lib_mqtt -Iinclude/components/lib_mqtt/include -Iinclude/components/tal_wifi -Iinclude/components/tal_wifi/include -Iinclude/components/lib_websocket -Iinclude/components/lib_websocket/include -Iinclude/components/lib_transport -Iinclude/components/lib_transport/include -Iinclude/components/lib_cJSON -Iinclude/components/lib_cJSON/include -Iinclude/components/svc_wifi_ffc -Iinclude/components/svc_wifi_ffc/include -Iinclude/components/base_uf -Iinclude/components/base_uf/include -Iinclude/components/tal_system_service -Iinclude/components/tal_system_service/include -Iinclude/components/tal_system_service/include/utilities -Iinclude/components/svc_wifi -Iinclude/components/svc_wifi/include -Iinclude/components/tal_bluetooth -Iinclude/components/tal_bluetooth/include -Iinclude/components/svc_api_wired -Iinclude/components/svc_api_wired/include -Iinclude/components/svc_mf_test -Iinclude/components/svc_mf_test/include -Iinclude/components/tal_lwip -Iinclude/components/tal_lwip/include -Iinclude/components/tal_lwip/include/lwip -Iinclude/components/tal_lwip/include/lwip/priv -Iinclude/components/tal_lwip/include/lwip/prot -Iinclude/components/tal_lwip/include/lwip/arch -Iinclude/components/tal_lwip/include/lwip/apps -Iinclude/components/tal_lwip/include/compat -Iinclude/components/tal_lwip/include/compat/posix -Iinclude/components/tal_lwip/include/compat/posix/sys -Iinclude/components/tal_lwip/include/compat/posix/arpa -Iinclude/components/tal_lwip/include/compat/posix/net -Iinclude/components/tal_lwip/include/compat/stdc -Iinclude/components/tal_lwip/include/netif -Iinclude/components/tal_lwip/include/netif/ppp -Iinclude/components/tal_lwip/include/netif/ppp/polarssl -Iinclude/components/svc_dp -Iinclude/components/svc_dp/include -Iinclude/components/base_security -Iinclude/components/base_security/include -Iinclude/components/svc_wired -Iinclude/components/svc_wired/include -Iinclude/components/svc_bt -Iinclude/components/svc_bt/include -Iinclude/components/base_event -Iinclude/components/base_event/include -Iinclude/components/tal_system -Iinclude/components/tal_system/include -Iinclude/components/tal_wired -Iinclude/components/tal_wired/include -Iinclude/components/svc_netmgr -Iinclude/components/svc_netmgr/include -Iinclude/components/lib_tls -Iinclude/components/lib_tls/include -Iinclude/components/lib_tls/include/mbedtls -Iinclude/components/lib_http -Iinclude/components/lib_http/include -Iinclude/components/svc_api_wifi -Iinclude/components/svc_api_wifi/include -Iinclude/components/tal_compatible -Iinclude/components/tal_compatible/include -Iinclude/components/tal_driver -Iinclude/components/tal_driver/include -Iinclude/components/svc_api_iot -Iinclude/components/svc_api_iot/include -Iinclude/components/svc_upgrade -Iinclude/components/svc_upgrade/include -Iinclude/components/tal_network -Iinclude/components/tal_network/include -Iinclude/components/svc_rpc -Iinclude/components/svc_rpc/include -Iinclude/components/base_db -Iinclude/components/base_db/include -Iinclude/components/svc_lan -Iinclude/components/svc_lan/include -Iinclude/components/svc_tuya_cloud -Iinclude/components/svc_tuya_cloud/include -Iinclude/components/svc_tuya_cloud/include/log_seq -Iinclude/components/svc_tuya_cloud/include/online_log -Iinclude/components/svc_tuya_cloud/include/tls -Iinclude/components/svc_tuya_cloud/include/protocol -Iinclude/components/svc_tuya_cloud/include/timer_task -Iinclude/components/svc_tuya_cloud/include/netcfg_qrcode -Iinclude/components/svc_tuya_cloud/include/iot_dns -Iinclude/components/svc_tuya_cloud/include/http -Iinclude/components/svc_tuya_cloud/include/mqtt -Iinclude -Iinclude/base -Iinclude/base/include -Iinclude/adapter -Iinclude/adapter/init -Iinclude/adapter/init/include -Iinclude/adapter/system -Iinclude/adapter/system/include -Iinclude/adapter/pwm -Iinclude/adapter/pwm/include -Iinclude/adapter/wired -Iinclude/adapter/wired/include -Iinclude/adapter/adc -Iinclude/adapter/adc/include -Iinclude/adapter/security -Iinclude/adapter/security/include -Iinclude/adapter/spi -Iinclude/adapter/spi/include -Iinclude/adapter/gpio -Iinclude/adapter/gpio/include -Iinclude/adapter/register -Iinclude/adapter/register/include -Iinclude/adapter/rtc -Iinclude/adapter/rtc/include -Iinclude/adapter/i2c -Iinclude/adapter/i2c/include -Iinclude/adapter/pinmux -Iinclude/adapter/pinmux/include -Iinclude/adapter/flash -Iinclude/adapter/flash/include -Iinclude/adapter/wifi -Iinclude/adapter/wifi/include -Iinclude/adapter/timer -Iinclude/adapter/timer/include -Iinclude/adapter/bluetooth -Iinclude/adapter/bluetooth/include -Iinclude/adapter/network -Iinclude/adapter/network/include -Iinclude/adapter/pm -Iinclude/adapter/pm/include -Iinclude/adapter/uart -Iinclude/adapter/uart/include -Iinclude/adapter/i2s -Iinclude/adapter/i2s/include -Iinclude/adapter/dac -Iinclude/adapter/dac/include -Iinclude/adapter/hci -Iinclude/adapter/hci/include -Iinclude/adapter/watchdog -Iinclude/adapter/watchdog/include -Iinclude/adapter/utilities -Iinclude/adapter/utilities/include -Iinclude/components -Iinclude/components/svc_devos -Iinclude/components/svc_devos/include -Iinclude/components/lib_mqtt -Iinclude/components/lib_mqtt/include -Iinclude/components/tal_wifi -Iinclude/components/tal_wifi/include -Iinclude/components/lib_websocket -Iinclude/components/lib_websocket/include -Iinclude/components/lib_transport -Iinclude/components/lib_transport/include -Iinclude/components/lib_cJSON -Iinclude/components/lib_cJSON/include -Iinclude/components/svc_wifi_ffc -Iinclude/components/svc_wifi_ffc/include -Iinclude/components/base_uf -Iinclude/components/base_uf/include -Iinclude/components/tal_system_service -Iinclude/components/tal_system_service/include -Iinclude/components/tal_system_service/include/utilities -Iinclude/components/svc_wifi -Iinclude/components/svc_wifi/include -Iinclude/components/tal_bluetooth -Iinclude/components/tal_bluetooth/include -Iinclude/components/svc_api_wired -Iinclude/components/svc_api_wired/include -Iinclude/components/svc_mf_test -Iinclude/components/svc_mf_test/include -Iinclude/components/tal_lwip -Iinclude/components/tal_lwip/include -Iinclude/components/tal_lwip/include/lwip -Iinclude/components/tal_lwip/include/lwip/priv -Iinclude/components/tal_lwip/include/lwip/prot -Iinclude/components/tal_lwip/include/lwip/arch -Iinclude/components/tal_lwip/include/lwip/apps -Iinclude/components/tal_lwip/include/compat -Iinclude/components/tal_lwip/include/compat/posix -Iinclude/components/tal_lwip/include/compat/posix/sys -Iinclude/components/tal_lwip/include/compat/posix/arpa -Iinclude/components/tal_lwip/include/compat/posix/net -Iinclude/components/tal_lwip/include/compat/stdc -Iinclude/components/tal_lwip/include/netif -Iinclude/components/tal_lwip/include/netif/ppp -Iinclude/components/tal_lwip/include/netif/ppp/polarssl -Iinclude/components/svc_dp -Iinclude/components/svc_dp/include -Iinclude/components/base_security -Iinclude/components/base_security/include -Iinclude/components/svc_wired -Iinclude/components/svc_wired/include -Iinclude/components/svc_bt -Iinclude/components/svc_bt/include -Iinclude/components/base_event -Iinclude/components/base_event/include -Iinclude/components/tal_system -Iinclude/components/tal_system/include -Iinclude/components/tal_wired -Iinclude/components/tal_wired/include -Iinclude/components/svc_netmgr -Iinclude/components/svc_netmgr/include -Iinclude/components/lib_tls -Iinclude/components/lib_tls/include -Iinclude/components/lib_tls/include/mbedtls -Iinclude/components/lib_http -Iinclude/components/lib_http/include -Iinclude/components/svc_api_wifi -Iinclude/components/svc_api_wifi/include -Iinclude/components/tal_compatible -Iinclude/components/tal_compatible/include -Iinclude/components/tal_driver -Iinclude/components/tal_driver/include -Iinclude/components/svc_api_iot -Iinclude/components/svc_api_iot/include -Iinclude/components/svc_upgrade -Iinclude/components/svc_upgrade/include -Iinclude/components/tal_network -Iinclude/components/tal_network/include -Iinclude/components/svc_rpc -Iinclude/components/svc_rpc/include -Iinclude/components/base_db -Iinclude/components/base_db/include -Iinclude/components/svc_lan -Iinclude/components/svc_lan/include -Iinclude/components/svc_tuya_cloud -Iinclude/components/svc_tuya_cloud/include -Iinclude/components/svc_tuya_cloud/include/log_seq -Iinclude/components/svc_tuya_cloud/include/online_log -Iinclude/components/svc_tuya_cloud/include/tls -Iinclude/components/svc_tuya_cloud/include/protocol -Iinclude/components/svc_tuya_cloud/include/timer_task -Iinclude/components/svc_tuya_cloud/include/netcfg_qrcode -Iinclude/components/svc_tuya_cloud/include/iot_dns -Iinclude/components/svc_tuya_cloud/include/http -Iinclude/components/svc_tuya_cloud/include/mqtt -DUSER_SW_VER="1.0.0" -DAPP_BIN_NAME="tuyaos_demo_quickstart" -o /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/output/t2_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/tuya_app_main.c.o -c /home/q/Documents/tuya/Projects/T2_TuyaOS-3.3.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c
