Moes matter bridge to Smartthings
allanlee
Hello,
I’m also encountering the same problem in this thread.
https://www.tuyaos.com/viewtopic.php?p=19088#p19088
There is an issue when bridging Zemismart Matter over Thread blind motors (connected to a MOES Matter hub) to SmartThings via Matter Bridge. In SmartThings, the MOES hub and all four blind motors either immediately go offline, or if they stay online, the four motors are only recognized as generic "Matter Thing" devices rather than actual blind motors. As a result, they cannot be controlled properly within SmartThings.
However, when using the same Matter Bridge setup with platforms like Home Assistant, Apple HomeKit, or Google Home, the devices also appear as "Matter Thing" but can still be fully controlled as blind motors. This issue seems to be specific to SmartThings and started occurring around late June to early July.
Currently, I’ve worked around the issue by individually pairing the four blind motors directly to SmartThings via Matter, and they function correctly this way. But I would like to know if it’s still possible to use the MOES hub as a Matter Bridge in parallel, as I was able to do so in early June without issues.
Here is the additional information:
MOES Matter Hub
Device ID: ebde5cfb7b84d4163bqppi
Zemismart Matter over Thread Blind Motors
Device IDs:
eb459e5xpuk3v5ei
eb91626hsfc0mkdu
eb22e6krjgxmyiwo
eb0b47nlgaviq9n5
Can you help me figure out what’s going wrong or provide a solution?
fangping.guo
Re: Moes matter bridge to Smartthings
Hello, allanlee,
I have already added the whitelist push for testing the gateway firmware. Please update the gateway firmware and unbind the curtain device to try again. Thank you.
allanlee
I updated the gateway firmware and reconnected the Moes gateway to SmartThings through Matter sharing, without previously unbinding the curtain motors.
It works perfectly now.
Thank you.
fangping.guo
:D
