调用Alarm.setBuiltInAlarmStatus无法修改告警状态
feige2023
  • Tuya MiniApp IDE 版本信息:2.3.10
    • App 应用版本信息:1.0.5
    • @ray-js/ray, @ray-js/panel-sdk的版本 :1.10.0
    • 移动设备信息:
    • 相关代码:
      import React, { Fragment,useCallback, useEffect } from 'react';
      import {Button, View } from '@ray-js/ray';
      import { Card } from '@/components/card';
      import { Title } from './components/title';
      import { IconFont} from '@/components';
      import { RadioGroup} from './components/radioGroup';
      import { Text,Image } from '@ray-js/ray';
      import Strings from '@/i18n';
      import { useConfig } from './useConfig';
      import { Dialog, Empty } from '@ray-js/smart-ui';
      import Layout from '@/components/layout';
      import { PopupView } from '@/components/popup';
      import Styles from './index.module.less';
      import { useProps } from '@ray-js/panel-sdk';
      import { useActions } from '@ray-js/panel-sdk';
      import { Switch, Divider } from '@ray-js/smart-ui';
      import { useState } from 'react';
      import { SmartAlarmAbility } from '@ray-js/panel-sdk';
      import { getLangKey } from '@ray-js/ray';
      import { HomeRes } from '@/res/images';
      import { Slider,Popup,Picker } from '@ray-js/smart-ui';
      export function Setting() {
      const [alarmList,setAlarmList] = useState([]);
      const Alarm = new SmartAlarmAbility();
      // 初始化
      useEffect(() => {
      const init = async () => {
      await Alarm.init();
      const alarms = await Alarm.getBuiltInAlarmList();
      updateAlarms(alarms);
      init();
      function updateAlarms(alarms:any)
      const maps = [];
      alarms.foreach(item=>{
      maps.push({
      'name':item.i18nData.name['en'],
      'id':item.id,
      'enable':item.enable
      setAlarmList(maps);
      ///设置状态
      async function setAlarmStaus(id:string,status:boolean)
      console.log("setAlarmStatus:",id,"disabled:",status);
      try{
      const [result,newAlarms] = await Alarm.setBuiltInAlarmEnable(id,status);
      console.log("setAlarmStatus result:",result);
      if(result){
      updateAlarms(newAlarms);
      }catch(e){
      console.log("设置状态错误",e);
      return (
      <View>
      {/** 忽略不相关代码 */}
      alarmList.map((item,index)=>{
      return (
      <View key={index}>
      <Text>{item.name}</Text>
      <Switch checked={item.enable} onChange={(event)=>{setAlarmStaus(item.id,!event.detail)}}></Switch>
      </View>
      </View>
      上述代码为关键代码,屏蔽了一些项目敏感信息。通过上述代码,能获取到的Alarm列表并正确显示,其中一个id为"LLuN3IhnGAvWbFD3",点击关闭告警,从IDE中的日志也可以获知,能打印正确的。具体参考附件
      - 日志信息:~错误日志或 IDE 运行日志等~
      - 问题描述(复现步骤):
      - 预期结果:能通过Switch切换该警告的状态
      - 实际结果:无法通过Switch切换
setBuiltInAlarmStatus无法修改告警状态的相关截图.zip
(221.87 KiB) Downloaded 331 times
Re: 调用Alarm.setBuiltInAlarmStatus无法修改告警状态
根据你提供附件网络请求里的所分析,大概率是因为 disabled 入参传反了。
feige2023
您好,我确定传入的参数中,disabled中传入的true,日志打印的如下
setAlarmStatus: LLuN3IhnGAvWbFD3 disabled: true
setAlarmStatus result: true
newAlarmList: (2) [{…}, {…}]
我也尝试过将disabled的状态改为false,网络请求还是跟附件截图中的一样。
没有脱敏的setAlarmStatus API。
async function setAlarmStatus(id:string,status:boolean){
try{
const [result,newAlarmList] = await Alarm.setBuiltInAlarmStatus({disabled:status,ruleIds:id});//'LLuN3IhnGAvWbFD3'
initCustomAlarm(langKey,newAlarmList);
console.log("newAlarmList:",newAlarmList);
}catch(err){
console.log("setAlarmStatus err:",err);
是否方便提供下设备 ID?目前无法查询到对应规则 ID 的调用记录。
feige2023
设备ID为:6cd36d0d6f4b36442bdtbe
可以先尝试下在 setBuiltInAlarmStatus 之前先调用下 getBuiltInAlarmList 是否正常?
feige2023
先调用await Alarm.getBuiltInAlarmList();后再调用await Alarm.setBuiltInAlarmStatus({disabled:status,ruleIds:id});就能正常工作,请问这是什么原因呢,我看官方API文档也没说set之前需要调用get才能生效呀?
这里应该是 SDK 的场景覆盖不足导致的问题,我们本周看看修复一下,因为正常都会先通过 getBuiltInAlarmList 拿到规则 ID 才可能去修改规则状态,而你这里看起来是写死了,导致的这个问题。
feige2023
您好,我是先通过useEffect钩子初始化Alarm并获取告警列表后再更新警告列表内容的,并不是写死。
await Alarm.init();
const customAlarm = await Alarm.getBuiltInAlarmList();
alarmList.forEach(item=>{
maps.push({
'name':item.i18nData.name[key],
'id':item.id,
'enable':item.enabled,
setAlarmList(maps)
setAlarmList(maps)
在警告列表Switch中,用的ruleIds也是getBuiltInAlarmList中获取到的。
我也反复核对过,上报的ruleIds跟在调用Alarm.setBuiltInAlarmStatus之前是否调用getBuiltInAlarmList打印的ruleIds并没有不同
https://developer.tuya.com/cn/miniapp/s ... iltInAlarm
目前提供的方式是比较推荐通过 hook 的方式接入,但上述您反馈的问题也是 SDK 的兼容不足导致,预计 7.97.10 会发布一个 beta 版本供您验证下
