createDpKit 中的new protocols.MicMusicTransformer();解析或者格式化有问题
MwM-Mai
import { protocols } from '@ray-js/panel-sdk';
export const MicMusicTransformer = new protocols.MicMusicTransformer();
export default {
MicMusicTransformer
const structuredAction = useStructuredActions()
使用structuredAction下发dreamlightmic_music_data数据的时候下发数据是
"v": 1,
"power": true,
"id": 0,
"isLight": 0,
"mode": 3,
"speed": 100,
"sensitivity": 50,
"a": 0,
"b": 0,
"c": 0,
"brightness": 100,
"colors": [
"hue": 0,
"saturation": 100
"hue": 120,
"saturation": 100
"hue": 240,
"saturation": 100
"hue": 60,
"saturation": 100
"hue": 180,
"saturation": 100
"hue": 300,
"saturation": 100
"hue": 0,
"saturation": 0
const micMusicData = useStructuredProps(props => props.dreamlightmic_music_data); 解析出来的数据中的colors有异常
以下是解析结果:
"v": 1,
"power": true,
"id": 0,
"isLight": 0,
"mode": 3,
"sensitivity": 50,
"speed": 100,
"a": 0,
"b": 0,
"c": 0,
"brightness": 100,
"colors": [
"hue": 0,
"saturation": 25600
"hue": 30820,
"saturation": 240
"hue": 25600,
"saturation": 15460
"hue": 180,
"saturation": 25601
"hue": 11364,
"saturation": 0
"hue": 0,
"saturation": null
crisiron
Re: createDpKit 中的new protocols.MicMusicTransformer();解析或者格式化有问题
麻烦提供一个解析异常的 dp 字符串
MwM-Mai
dp字符串指的是什么,dp的标识符吗
crisiron
可先使用这个解析函数开发
/* eslint-disable no-param-reassign */
import { utils } from "@ray-js/panel-sdk";
import { lampStandardDpCodes } from "../../utils";
const { generateDpStrStep } = utils;
type TMusic = {
  v: number; // 版本
  power: boolean;
  isLight: number;
  mode: number;
  speed: number;
  sensitivity: number; // 灵敏度
  a: number;
  b: number;
  c: number;
  brightness: number;
  colors: { hue: number; saturation: number }[];
export const DefaultLocalMusicData = {
  v: 1,
  power: true,
  isLight: 0, // 0 无声时灯灭、 1无声时灯维持10%亮度
  mode: 3, // 0跳变 1渐变 2 呼吸 3 闪烁
  speed: 100,
  sensitivity: 50,
  a: 0,
  b: 0,
  c: 0,
  brightness: 100,
  colors: [
    { hue: 0, saturation: 100 },
    { hue: 120, saturation: 100 },
    { hue: 240, saturation: 100 },
    { hue: 60, saturation: 100 },
    { hue: 80, saturation: 100 },
    { hue: 280, saturation: 100 },
export default class MicMusicFormater {
  uuid: string;
  defaultValue: TMusic = DefaultLocalMusicData;
  constructor(
    uuid = lampStandardDpCodes.dreamMicMusicCode,
    defaultValue = {} as TMusic
    this.uuid = uuid;
    this.defaultValue = this.defaultValue || defaultValue;
   * 解析场景各个单元
   * @param generator generator 函数
  parseUnits(step) {
    const result = [];
    // eslint-disable-next-line prefer-const
    for (; true; ) {
      const hue = step(4).value;
      let { value: saturation, done } = step(2);
      result.push({
        hue,
        saturation,
      if (done) {
        break;
    return result;
  parser(value: string) {
    const { length } = value;
    if (!length) {
      console.warn(
        "dp数据有问题,无法解析",
        value
      return this.defaultValue;
    const step = generateDpStrStep(value);
    const v = step(2).value;
    const power = step(2).value;
    let id = step(2).value;
    const opt = Array.from(step(2).value.toString(2).padStart(8, "0")).map(
      (i) => Number(i)
    const isLight = parseInt(opt.slice(0, 4).join("").padStart(8, "0"), 2);
    const mode = parseInt(opt.slice(4).join("").padStart(8, "0"), 2);
    // 摇滚、爵士、古典 特殊处理
    if (id === 0) {
      if (isLight === 0 && mode === 3) id = 0;
      if (isLight === 0 && mode === 2) id = 1;
      if (isLight === 1 && mode === 2) id = 2;
    } else if (id === 1) id = 3;
    else if (id === 2) id = 4;
    else if (id === 3) id = 5;
    const speed = step(2).value;
    const sensitivity = step(2).value;
    const a = step(2).value;
    const b = step(2).value;
    const c = step(2).value;
    const brightness = step(2).value;
    const colors = this.parseUnits(step);
    const res = {
      v,
      power: Boolean(power),
      id,
      isLight,
      mode,
      sensitivity,
      speed,
      a,
      b,
      c,
      brightness,
      colors,
    console.log("dreamlightmic_music_data parser", res);
    return res;
  to16(value: number, length: number): string {
    let result = Number(value).toString(16);
    result = result.padStart(length, "0");
    return result;
  formatter(data: TMusic): string {
    if (+data.id === 0) {
      data.isLight = 0;
      data.mode = 3;
    if (+data.id === 1) {
      data.isLight = 0;
      data.mode = 2;
    if (+data.id === 2) {
      data.isLight = 1;
      data.mode = 2;
    const {
      v,
      power,
      isLight,
      mode,
      sensitivity,
      speed,
      a,
      b,
      c,
      brightness,
      colors,
    } = data;
    const fixedIds = [0, 0, 0, 1, 2, 3];
    const id = fixedIds[data.id];
    const lightByte = parseInt(String(isLight), 10)
      .toString(2)
      .padStart(4, "0");
    const modeByte = parseInt(String(mode), 10).toString(2).padStart(4, "0");
    const optNum = parseInt(lightByte + modeByte, 2);
    const vHex = this.to16(v, 2);
    const powerHex = this.to16(Number(power), 2);
    const idHex = this.to16(id, 2);
    const optNumHex = this.to16(optNum, 2);
    const speedHex = this.to16(speed, 2);
    const sensitivityHex = this.to16(sensitivity, 2);
    const aHex = this.to16(a, 2);
    const bHex = this.to16(b, 2);
    const cHex = this.to16(c, 2);
    const brightnessHex = this.to16(brightness, 2);
    if (colors && colors.length) {
      const units = colors
        .map(
          ({ hue, saturation }) =>
            `${this.to16(hue, 4)}${this.to16(saturation, 2)}`
        .join("");
      const res = `${vHex}${powerHex}${idHex}${optNumHex}${speedHex}${sensitivityHex}${aHex}${bHex}${cHex}${brightnessHex}${units}`;
      return res;
    const res = `${vHex}${powerHex}${idHex}${optNumHex}${speedHex}${sensitivityHex}${aHex}${bHex}${cHex}`;
    return res;
