LampCirclePickerWhite 的锚点会落在圆盘外面
  • Tuya MiniApp IDE 版本信息:0.8.9;
    • App 应用版本信息: 设置-关于中进行查看~
    • "@ray-js/ray": "1.6.1","@ray-js/ray": "1.6.1",
    • 移动设备信息:手机型号及系统
    • 相关代码:"@ray-js/components-ty-lamp": "2.0.2"
    • 日志信息:错误日志或 IDE 运行日志等~
    • 问题描述(复现步骤):"@ray-js/components-ty-lamp": "2.0.2" LampCirclePickerWhite 在选择预设的色温值传给色盘时,色盘的锚点会落在圆盘外
    • 预期结果:LampCirclePickerWhite 的锚点在传入 temperature 的值时,永远落在圆盘内
    • 实际结果:如题 LampCirclePickerWhite 的锚点会落在圆盘外面
crisiron
Re: LampCirclePickerWhite 的锚点会落在圆盘外面
15002075425 2025年 Apr 14日 17:26
    • 移动设备信息:手机型号及系统
麻烦提供下,可复现的代码
15002075425
.whiteView {
  overflow-y: scroll;
  padding-bottom: 20px;
  .circleView {
    width: 100vw;
    display: flex;
    justify-content: center;
    align-items: center;
    padding: 10px 0;
    height: 270px;
    margin-bottom: 12px;
  .colorItem {
    width: 28px;
    height: 28px;
    border-radius: 14px;
    margin-right: 10px;
    display: 'inline-block';
  .modeTabItemColor {
    width: 28px;
    height: 28px;
  .modeTabItemColorActive {
    width: 22px;
    height: 22px;
    border-radius: 11px;
import React, { useEffect, useState } from 'react';
import { View } from '@ray-js/ray';
import { useProps, utils } from '@ray-js/panel-sdk';
import { LampCirclePickerWhite } from '@ray-js/components-ty-lamp';
import styles from './index1.module.less';
const defaultWhite = [
  { temperature: 0, brightness: 1000 },
  { temperature: 500, brightness: 1000 },
  { temperature: 1000, brightness: 1000 },
const { brightKelvin2rgb } = utils;
interface Props {
  show: boolean;
  showParent: boolean;
export const ColorComponent: React.FC<Props> = React.memo(({ show }) => {
  const [temp, setTemp] = useState(1000);
  const [activeIndex, setActiveIndex] = useState(-1);
  const tempValue = useProps(dpState => dpState.temp_value);
  useEffect(() => {
    setTemp(tempValue);
  }, [tempValue]);
  useEffect(() => {
    if (activeIndex === -1) return;
    const _colorItem = defaultWhite[activeIndex];
    if (_colorItem) {
      handleOnChangeTemperature(_colorItem.temperature);
  }, [activeIndex]);
  const handleChecked = (_activeIndex: number) => {
    if (_activeIndex === activeIndex) {
      setActiveIndex(-1);
      return;
    setActiveIndex(_activeIndex);
  const handleOnChangeTemperature = (_temp: number) => {
    setTemp(_temp);
  const getColors = (
    colorList: {
      hue?: number;
      saturation?: number;
      value?: number;
      brightness?: number;
      temperature?: number;
    return colorList.map(color => {
      const { brightness, temperature } = color;
      const rgb = brightKelvin2rgb(brightness, temperature);
      return rgb;
  const itemStyle = {
    display: 'inline-block',
  return (
    <View className={styles.whiteView}>
      <View className={styles.circleView}>
        {show && (
          <LampCirclePickerWhite
            thumbRadius={15}
            temperature={temp}
            radius={120}
            onTouchStart={setTemp}
            onTouchEnd={(_temp: number) => {
              handleOnChangeTemperature(_temp);
            canvasId="white_picker_1"
      </View>
      <View className={styles.colorCollectView}>
        <View>
          {getColors(defaultWhite).map((color, index) => {
            return (
              <View
                key={color + index}
                className={styles.colorItem}
                style={{ ...itemStyle }}
                onClick={() => handleChecked(index)}
                <View
                  className={styles.modeTabItemColor}
                  style={{ backgroundColor: color || '#1F2022' }}
              </View>
        </View>
      </View>
    </View>
ColorComponent.displayName = 'ColorComponent';
export default ColorComponent;
操作:将锚点拖动到靠近底部,然后点击预设色温值0 或者 1000 (最左边、最右边)
crisiron
新版本已修复,在package.json 中 配置
"resolutions": {
"@ray-js/lamp-circle-picker-white": "0.0.3-beta-5"
}, 然后执行 yarn 即可安装最新版本的,测试后没问题发布正式版本
15002075425
已解决
