【求助】PWM怎么输出不了
jujuju
使用tuyaos 3.11.2版本的T5 SDK,tuyaos_demo_examples测试PWM, TUYA_PWM_NUM_0对应哪个引脚? 我用逻辑分析仪器抓的P6,没有波形; 是不是没有实现PWM功能?在SDK中都搜不到pwm的引脚map
一个网友
Re: 【求助】PWM怎么输出不了
您好,
a) pwm 0 - 4分别对应gpio为 P18,P24,P32,P34,P36
b) 在tkl_pwm.c中,有一个通道转换底层pwm id的接口
pwm_chan_t ty_to_bk_pwm(TUYA_PWM_NUM_E ch_id)
    pwm_chan_t pwm = PWM_ID_MAX;
    switch(ch_id) {
        case TUYA_PWM_NUM_0:
            pwm = PWM_ID_0;
        break;
        case TUYA_PWM_NUM_1:
            pwm = PWM_ID_4;
        break;
        case TUYA_PWM_NUM_2:
            pwm = PWM_ID_6;
        break;
        case TUYA_PWM_NUM_3:
            pwm = PWM_ID_8;
        break;
        case TUYA_PWM_NUM_4:
            pwm = PWM_ID_10;
        break;
        default:
        break;
return  pwm;
这里实际对应的是 vendor/T5/t5_os/bk_idk/middleware/soc/bk7258/soc/gpio_map.h文件中的GPIO_PWM_MAP_TABLE:
#define GPIO_PWM_MAP_TABLE \
		{GPIO_18,  GPIO_DEV_PWM0},\
		{GPIO_19,  GPIO_DEV_PWM1},\
		{GPIO_8,  GPIO_DEV_PWM2},\
		{GPIO_9,  GPIO_DEV_PWM3},\
		{GPIO_24, GPIO_DEV_PWM4},\
		{GPIO_25, GPIO_DEV_PWM5},\
		{GPIO_32, GPIO_DEV_PWM6},\
		{GPIO_33, GPIO_DEV_PWM7},\
		{GPIO_34, GPIO_DEV_PWM8},\
		{GPIO_35, GPIO_DEV_PWM9},\
		{GPIO_36, GPIO_DEV_PWM10},\
		{GPIO_37, GPIO_DEV_PWM11},\
努力写bug……
