Tuya devices not showing in smartthings via zemismart matter hub
adel1981
Hi,
I connected zemismart m6 matter hub as gateway to smartthings and some of the devices are missing:
  1. 4 gang touch switch
    Virtual id: bf632f94ed474f028ephml
  2. 4 gand touch switch
    Virtual id bf8e00db03f009f1bds5h9
  3. 4 gand touch switch
    Virtual id bf9cfe9f1622d87826okfs
  4. Boiler timer switch
    Virtual id bfe812c362633a931c6ims
How can you help me please?
qiusui
Re: Tuya devices not showing in smartthings via zemismart matter hub
adel1981 2025年 Feb 9日 01:35
Hi,
Hello adel1981,
I've updated your device configuration. Among them, I configured the Boiler timer switch as a 1-way switch.
You need to remove the device from the original gateway and then configure and bridge the device again for the new configuration file to take effect.
Follow these steps to try it out and look forward to hearing from you next time.
adel1981
1st of all thank you very much.
I will try later and I hope all will work as expected.
Another question please,
There are another switches that include curtains switches and they appear in smartthings as 2 separate regular switches.
Is there an option to configure as curtains?
For example
Virtual id bf2f0418967676ca45ui2r
Switches 2+5 and 3+6 are for curtains and 1,4 regular lights.
Thanks.
qiusui
adel1981 2025年 Feb 10日 16:10
For example
Thanks.
I have read the design scheme of your switch. I can configure its six switches, but I cannot distinguish between curtain or regular lights. You need to realize this by yourself.
Would you like me to help you configure this switch as well?
adel1981
This switch appear in smartthings and works fine, just the issue of the curtain configuration.
I can manage with this.
So thank you very much for now
qiusui
adel1981 2025年 Feb 10日 17:26
Ok, You're welcome.
adel1981
Hi again,
I have 2 more devices that not appear in smartthings
  1. Virtual id bf1963f8fb54a96d92t3aq
  2. Virtual id bf8ac2e7335e072a0eknxa
qiusui
adel1981 2025年 Feb 11日 23:28
Hi again,
Ok, but I'm busy today. I'll try to finish it this week.
qiusui
I finished it on my lunch break. You can try it. I went back to my other work in the afternoon.
adel1981
Thank you, I appreciate this 🙏
