Calculated Sign in PHP sign invalid 1004
andher74
Hi
in the Documentation the sign calc is
$sign = strtoupper(hash_hmac("sha256", $clientsec . $timestamp13, $SecretKey));
4 sign method
TuyaCloud provide two sign algorithm based on different scenario:
• before get token:sign = HMAC-SHA256(client_id + t, secret).toUpperCase()
• after get token:sign = HMAC-SHA256(client_id + access_token + t, secret).toUpperCase()
Please Help!!
Thank you
panda-cat
Re: Calculated Sign in PHP sign invalid 1004
The signature verification scheme in your question is actually the same way of signature verification, but whether access_token is empty or not can only be empty when obtaining the token interface. In addition, I looked at the parameter information of your signature verification, and it should be that the URL and request parameter information are missing, so the signature verification fails. You can refer to the signature verification process parameters in the postman case(https://developer.tuya.com/en/docs/iot/ ... o385w1svns).
Postman case request signature processing flow:
(function () {
    var timestamp = getTime();
    pm.environment.set("timestamp",timestamp);
const clientId = pm.environment.get("client_id");
const secret = pm.environment.get("secret");
var accessToken = "";
if(pm.environment.has("easy_access_token")){
    accessToken = pm.environment.get("easy_access_token")
const httpMethod = pm.request.method.toUpperCase();
const query = pm.request.url.query;
const mode = pm.request.body.mode;
const headers = pm.request.headers;
// sha256
var signMap = stringToSign(query, mode, httpMethod, secret)
var urlStr = signMap["url"]
var signStr = signMap["signUrl"]
pm.request.url = pm.request.url.host + urlStr
var nonce = ""
if (headers.has("nonce")) {
    var jsonHeaders = JSON.parse(JSON.stringify(headers))
    jsonHeaders.forEach(function(item){
        if (item.key == "nonce" && !item.disabled) {
            nonce = headers.get("nonce")
var sign = calcSign(clientId, accessToken, timestamp, nonce, signStr, secret);
pm.environment.set('easy_sign', sign);
function getTime(){
    var timestamp = new Date().getTime();
    return timestamp;
// Business verification calculation
function calcSign(clientId,accessToken,timestamp,nonce,signStr,secret){
    var str = clientId + accessToken +timestamp + nonce + signStr;
    var hash = CryptoJS.HmacSHA256(str, secret);
    var hashInBase64 = hash.toString();
    var signUp = hashInBase64.toUpperCase();
    return signUp;
// Generate signature string
function stringToSign(query, mode, method, secret){
    var sha256 = "";
    var url = "";
    var headersStr = ""
    var map = {}
    var arr = []
    var bodyStr = ""
    if(query){
        toJsonObj(query, arr, map)
    if (pm.request.body && mode) {
        if (mode != "formdata" && mode != "urlencoded"){
            bodyStr = replacePostmanParams(pm.request.body.toString())
        } else if (mode == "formdata") {
           // Traversing form key value pairs
            toJsonObj(pm.request.body["formdata"], arr, map)
        } else if (mode == "urlencoded") {
            toJsonObj(pm.request.body["urlencoded"], arr, map)
    sha256 = CryptoJS.SHA256(bodyStr)
    arr = arr.sort()
    arr.forEach(function(item){
            url += item + "=" + map[item] + "&"
    if (url.length > 0 ) {
        url = url.substring(0, url.length-1)
        url = "/" + pm.request.url.path.join("/") + "?" + url
    } else {
if (headers.has("Signature-Headers") && headers.get("Signature-Headers")) { var jsonHeaders = JSON.parse(JSON.stringify(headers)) var signHeaderStr = headers.get("Signature-Headers") const signHeaderKeys = signHeaderStr.split(":") signHeaderKeys.forEach(function(item){ var val = "" if (isSelected(jsonHeaders,item) && headers.get(item)) { val = headers.get(item) } headersStr += item + ":" + val + "\n" }) } var map = {} url = replacePostmanUrl(url) map["signUrl"] = method + "\n" + sha256 + "\n" + headersStr + "\n" + url map["url"] = url return map } function isSelected(jsonHeaders,key){ var result = true; jsonHeaders.forEach(function(item){ if (item.key == key && item.disabled) { result = false } }) return result } function replacePostmanParams(str){ while(str.indexOf("{{")!=-1&&str.indexOf("}}")!=-1){ const key = str.substring(str.indexOf("{{")+2,str.indexOf("}}")) var value = pm.environment.get(key) if(!value) value="" str = str.replace("{{"+key+"}}", value) } return str } function replacePostmanUrl(str){ console.log("str:",str) while(str.indexOf("{{")!=-1&&str.indexOf("}}")!=-1){ const key = str.substring(str.indexOf("{{")+2,str.indexOf("}}")) var value = pm.environment.get(key) if(!value) value="" str = str.replace("{{"+key+"}}", value) } while(str.indexOf(":")!=-1){ const tempStr = str.substring(str.indexOf(":")+1,str.length); var key = ""; if(tempStr.indexOf("/")!=-1){ key = tempStr.substring(0,tempStr.indexOf("/")) }else if(tempStr.indexOf("?")!=-1){ key = tempStr.substring(0,tempStr.indexOf("?")) }else { key = tempStr.substring(0,tempStr.length) } var value = pm.request.url.variables.get(key) if(!value) value="" str = str.replace(":"+key, value) } return str } function toJsonObj(params, arr, map){ var jsonBodyStr = JSON.stringify(params) var jsonBody = JSON.parse(jsonBodyStr) jsonBody.forEach(function(item){ if(!item.disabled){ arr.push(item.key) map[item.key] = item.value } }) }
