ESP32S3_TuyaOS-3.6.7如何配网,有没有蓝牙配网的功能?
726550914@qq.com
1.长按按键后,显示
long press,remove device
然后不断打印,下面的log,app扫描,没有发现设备
D (00:04:46.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:47.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:48.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:49.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:50.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
I (00:04:50.981) TKL_LOG: [01-01 00:04:50 ty D][tuya_devos_health.c:70] feed watchdog
D (00:04:51.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:52.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:53.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:54.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:55.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
I (00:04:55.981) TKL_LOG: [01-01 00:04:55 ty D][tuya_devos_health.c:70] feed watchdog
D (00:04:56.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:57.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:58.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:04:59.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:00.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
I (00:05:00.981) TKL_LOG: [01-01 00:05:00 ty D][tuya_devos_health.c:70] feed watchdog
D (00:05:01.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:02.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:03.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:04.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:05.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
I (00:05:05.981) TKL_LOG: [01-01 00:05:05 ty D][tuya_devos_health.c:70] feed watchdog
esp>
esp> D (00:05:06.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:07.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:08.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:09.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:10.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
I (00:05:10.981) TKL_LOG: [01-01 00:05:10 ty D][tuya_devos_health.c:70] feed watchdog
D (00:05:11.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
D (00:05:12.880) esp_netif_lwip: esp_netif_get_ip_info esp_netif:0x3fcf3c40
Re: ESP32S3_TuyaOS-3.6.7如何配网,有没有蓝牙配网的功能?
有的,你用默认的quickstart demo就可以通过蓝牙来配网。
726550914@qq.com
不知道哪里出了问题,现在是能编译过了,运行也没出错,按键也没问题,
就是
改了这里、
#define PID "uiiyltkjmkhwumga"
#define UUID "uuid8c979a2cea91955c"
#define AUTHKEY "8TxpnLMkuovxRtlh5TfICLipjzZKnc07"
PID UUID AUTHKEY三个都改了,配不了网,然后又试了把PID不改,只改 UUID AUTKEY,也没有发现设备
你把完整日志发出来。
726550914@qq.com
从长按按键后,输出的日志在附件中,麻烦帮忙看下,感谢
log20240429.txt
(35.87 KiB) Downloaded 370 times
再发一下上电之后的log?从这个log上看,是没有蓝牙相关的log。你看看你的tuya_iot_config.h,看看里面的ENABLE_BT_NETCFG的值。
726550914@qq.com
上电日志,上面那个日志,长按删除设备后,它也是重启
log20240429-2.txt
(33.87 KiB) Downloaded 441 times
726550914@qq.com
#define STACK_SIZE_MF_TEST 8192
// CONFIG_ENABLE_LWIP is not set
#define ENABLE_BT_SERVICE 1
#define ENABLE_BT_NETCFG 1
// CONFIG_ENABLE_BT_ACTIVE is not set
看了,这个蓝牙是打开的,
726550914@qq.com
726550914@qq.com 2024年 Apr 29日 14:44
您好,能分析出原因吗?
你这个log很奇怪,没有蓝牙相关的功能初始化,看配置蓝牙是支持的。上电之后log呢?不是长按按键之后。
