【已解决】TUYAOS-3.9.0编译报错-TLSR8250
freelifewe
1.我按安装指导安装了python3.8.10
2.通过命令也确认安装成功了
python -V
Python 3.8.10
python3 -V
Python 3.8.10
3.pip跟着python也确认安装成功了
pip list
Package Version
pip 21.1.1
问题:但是编译还是报pip找不到
报错提示信息:
File "./vendor/tlsr825x_ble/prepare.py", line 6, in <module>
import pip
ModuleNotFoundError: No module named 'pip'
execution failed !!!
逻辑的院子
Contact:
Re: 【求助】TUYAOS-3.9.0编译报错-TLSR8250
可以贴一下您点击完 “build project” 之后终端运行的命令吗?
freelifewe
PS C:\Users\52698\Documents\tuya\Projects\TLSR8250_TuyaOS-3.9.0\software\TuyaOS> cd c:\Users\52698\Documents\tuya\Projects\TLSR8250_TuyaOS-3.9.0\software\TuyaOS\
PS C:\Users\52698\Documents\tuya\Projects\TLSR8250_TuyaOS-3.9.0\software\TuyaOS> & C:\Users\52698\.tuya\venv\Scripts\python.exe .\build_app.py apps\tuyaos_demo_roaming tuyaos_demo_roaming 1.0.0
4
DEMO_PATH: apps/tuyaos_demo_roaming
DEMO_NAME: tuyaos_demo_roaming
DEMO_FIRMWARE_VERSION: 1.0.0
BOARD_NAME: tlsr825x_ble
BUILD_COMMAND: build
build-pre...
import pip
逻辑的院子
Contact:
在终端中运行这个命令试试:
C:\Users\52698\.tuya\venv\Scripts\python.exe -m ensurepip --upgrade
freelifewe
命令看上去生效了,但是又报git找不到,这个我也装了的,git -v可以看到版本
C:\Users\52698>git -v
git version 2.43.0.windows.1
报错信息:
4
build-pre...
install GitPython
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
ERROR: Exception:
File "./vendor/tlsr825x_ble/prepare.py", line 15, in <module>
from git import Repo
ModuleNotFoundError: No module named 'git'
During handling of the above exception, another exception occurred:
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\cli\base_command.py", line 180, in main
status = self.run(options, args)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\cli\req_command.py", line 204, in wrapper
return func(self, options, args)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\commands\install.py", line 318, in run
requirement_set = resolver.resolve(
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\resolution\resolvelib\resolver.py", line 127, in resolve
result = self.
result = resolver.resolve(
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 473, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 341, in resolve
name, crit = self._merge_into_criterion(r, parent=None)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 172, in merge_into_criterion
if not criterion.candidates:
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\resolvelib\structs.py", line 139, in bool
return bool(self.
sequence)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 143, in bool
return any(self)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 129, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 30, in iter_built
for version, func in infos:
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 258, in iter_index_candidate_infos
result = self.
finder.find_best_candidate(
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\package_finder.py", line 879, in find_best_candidate
candidates = self.find_all_candidates(project_name)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\package_finder.py", line 824, in find_all_candidates
page_candidates = list(page_candidates_it)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\sources.py", line 134, in page_candidates
yield from self.candidates_from_page(self.link)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\package_finder.py", line 783, in process_project_url
html_page = self._link_collector.fetch_page(project_url)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\collector.py", line 512, in fetch_page
return _get_html_page(location, session=self.session)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\collector.py", line 422, in _get_html_page
resp = _get_html_response(url, session=session)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\index\collector.py", line 120, in get_html_response
resp = session.get(
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\requests\sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_internal\network\session.py", line 449, in request
return super().request(method, url, *args, **kwargs)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\requests\sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\requests\sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\cachecontrol\adapter.py", line 53, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\requests\adapters.py", line 439, in send
resp = conn.urlopen(
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 696, in urlopen
self.
prepare_proxy(conn)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 964, in prepare_proxy
conn.connect()
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\urllib3\connection.py", line 359, in connect
conn = self.
connect_tls_proxy(hostname, conn)
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\urllib3\connection.py", line 500, in connect_tls_proxy
return ssl_wrap_socket(
File "C:\Users\52698\.tuya\venv\lib\site-packages\pip\_vendor\urllib3\util\ssl
.py", line 432, in ssl_wrap_socket
ssl_sock = ssl_wrap_socket_impl(sock, context, tls_in_tls)
.py", line 474, in ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock)
File "E:\Python 3.8.10\lib\ssl.py", line 500, in wrap_socket
return self.sslsocket_class.
create(
File "E:\Python 3.8.10\lib\ssl.py", line 997, in _create
raise ValueError("check_hostname requires server_hostname")
ValueError: check_hostname requires server_hostname
File "./vendor/tlsr825x_ble/prepare.py", line 18, in <module>
逻辑的院子
Contact:
运行:
C:\Users\52698\.tuya\venv\Scripts\pip install GitPython
如果再遇到别的(xxxx)一样的运行命令
C:\Users\52698\.tuya\venv\Scripts\pip install xxxx
freelifewe
这个命令没法执行成功
C:\Users\52698\.tuya\venv\Scripts>pip install GitPython
ERROR: Exception:
File "e:\python 3.8.10\lib\site-packages\pip\_internal\cli\base_command.py", line 180, in main
File "e:\python 3.8.10\lib\site-packages\pip\_internal\cli\req_command.py", line 204, in wrapper
File "e:\python 3.8.10\lib\site-packages\pip\_internal\commands\install.py", line 318, in run
File "e:\python 3.8.10\lib\site-packages\pip\_internal\resolution\resolvelib\resolver.py", line 127, in resolve
result = self.
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 473, in resolve
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 341, in resolve
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 172, in merge_into_criterion
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\resolvelib\structs.py", line 139, in bool
return bool(self.
sequence)
File "e:\python 3.8.10\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 143, in bool
return any(self)
File "e:\python 3.8.10\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 129, in <genexpr>
File "e:\python 3.8.10\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 30, in iter_built
File "e:\python 3.8.10\lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 258, in iter_index_candidate_infos
result = self.
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\package_finder.py", line 879, in find_best_candidate
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\package_finder.py", line 824, in find_all_candidates
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\sources.py", line 134, in page_candidates
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\package_finder.py", line 783, in process_project_url
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\collector.py", line 512, in fetch_page
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\collector.py", line 422, in _get_html_page
File "e:\python 3.8.10\lib\site-packages\pip\_internal\index\collector.py", line 120, in get_html_response
resp = session.get(
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\requests\sessions.py", line 555, in get
File "e:\python 3.8.10\lib\site-packages\pip\_internal\network\session.py", line 449, in request
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\requests\sessions.py", line 542, in request
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\requests\sessions.py", line 655, in send
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\cachecontrol\adapter.py", line 53, in send
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\requests\adapters.py", line 439, in send
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 696, in urlopen
self.
prepare_proxy(conn)
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 964, in prepare_proxy
conn.connect()
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\urllib3\connection.py", line 359, in connect
conn = self.
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\urllib3\connection.py", line 500, in connect_tls_proxy
File "e:\python 3.8.10\lib\site-packages\pip\_vendor\urllib3\util\ssl
File "e:\python 3.8.10\lib\ssl.py", line 500, in wrap_socket
create(
File "e:\python 3.8.10\lib\ssl.py", line 997, in _create
逻辑的院子
Contact:
看起来似乎是你的网络有问题,有没有开启VPN之类的,可以关掉试试
freelifewe
看来是编译成功解决了,感谢啊。
[o-list] tc32-elf-objdump -x -D -l -S $ELF > $LST
[o-bin] tc32-elf-objcopy -O binary $ELF $OUTPUT/output.bin
[o-size] tc32-elf-size -t $ELF
text data bss dec hex filename
136380 4908 20989 162277 279e5 .log/output.elf
136380 4908 20989 162277 279e5 (TOTALS)
build end, create final fw...
copy ./.log/output.bin -> UG
copy ./.log/output.bin -> UA
copy ./.log/output.bin -> QIO
copy ./.log/output.bin -> PROD
build success
freelifewe
感谢,耐心支持。
