System Environment: Linux, Ubuntu 20.04_amd64
Compilation Time and Notes:
- When executing
build.shfor the first time, it will compile the vendor, taking between 5 to 20 minutes, depending on CPU performance. There might be no log output during kernel compilation, so please be patient. - Errors during the vendor compilation won't immediately halt the process. You'll need to look upward to locate issues. Use "error" as a keyword for searching to pinpoint and resolve compilation problems more accurately.
- When executing
Installing Dependencies:
apt install autoconf automake cmake gettext whois -y apt install bc bison flex tree zip -yResolving
fatal error: openssl/aes.h: No such file or directorymessage:Code: Select all
apt-get install libssl-devFixing the Python Not Found Issue:
Python 2 is required during the vendor compilation. Install Python 2 and set it as the default Python program by creating a symbolic link:Code: Select all
apt install python2 ln -s /usr/bin/python2 /usr/bin/pythonResolving Python's Failure to Locate the yaml Module:
apt-get install python-yamlAddressing
mips-linux-xgcc: No such file or directorymessage:Code: Select all
dpkg --add-architecture i386 apt-get update apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 zlib1g:i386 -y
Hope this helps you and others in smoothly compiling gateway programs using Tuya Wind IDE!
