Dear tuya developers, could you please add support to link tuya with MelCloud?
Thank you very much
Thank you very much
We currently do not support direct integration with MEICloud. If you want to develop an app for remote control of your Mitsubishi central air conditioner using the Tuya app or Tuya SDK, I speculate that you can control the Mitsubishi central air conditioner through VRF. Subsequently, you can use the Tuya app or SDK to connect to the VRF for network configuration and achieve remote control
On the adaptation of third-party platforms, as @daxiong said. What interests me more is which specific platform do you refer to as MelCloud? Can you please send me its official website link? And why do you have such a need? ![]()
Here is the link to MelCloud: https://melcloud.com
I have an air conditioner Mitsubishi, and would like to be able to control it through tuya. MelCloud works with Google home and Alexa (they can be linked), and I thought it would be great, if tuya could also link to it. Thank you
woa 2023年 Nov 27日 16:49Here is the link to MelCloud: https://melcloud.com
Got it. Do you have any other devices that Tuya App can control?
Yeah, exactly - I have a humidity and temperature sensor
https://a.aliexpress.com/_EIb1AKD
And I want tuya to turn on the air conditioner when the temperature drops below, or raises above the specified degrees.
There is currently no way to control the Mitsubishi's MelCloud through tuya, although MelCloud openly supports linking, and even provides with api. If only tuya could add it, then we could use MelCloud with tuya. Thank you
woa 2023年 Nov 28日 04:12There is currently no way to control the Mitsubishi's MelCloud through tuya, although MelCloud openly supports linking, and even provides with api. If only tuya could add it, then we could use MelCloud with tuya. Thank you
Sorry, as DaXiong mentioned, there are currently no plans to integrate the Tuya APP into the third-party IoT system. If you have development capabilities, you can try to understand the HA access methods. You can refer to the document: https://developer.tuya.com/en/docs/iot/ ... eqjig0utdd
