【已解决】【中控】【TuyaOS SDK】子设备绑定的时候返回OPRT_SVC_HTTP_SERV_VRFY_FAIL
wyh
1) 开发包全称:tuyaos-gw-integrated_5.0.4_rk3308_wifi-cc-tpp01z_0.1.11
2) 问题现象:子设备绑定的时候返回服务端绑定失败OPRT_SVC_HTTP_SERV_VRFY_FAIL
-18 15:54:19 TUYA D][tuya_tls.c:1390] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[10-18 15:54:19 TUYA D][tuya_tls.c:1429] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE
[10-18 15:54:19 TUYA D][tuya_tls.c:1497] load tuya cert.
[10-18 15:54:19 TUYA D][tuya_tls.c:1502] parse crt <0> len <2002> ret <0>
[10-18 15:54:19 TUYA D][tuya_tls.c:1502] parse crt <1> len <1028> ret <0>
[10-18 15:54:19 TUYA D][tuya_iot_com_api.c:254] tuya public url
[10-18 15:54:19 TUYA D][tuya_tls.c:1614] socket fd is set. set to inner send/recv to handshake
[10-18 15:54:19 TUYA D][tuya_tls.c:1674] handshake finish for a2.tuyacn.com. set send/recv to user set
[10-18 15:54:19 TUYA D][tuya_tls.c:1683] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[10-18 15:54:19 TUYA D][httpc.c:641] Connect: a2.tuyacn.com Port: 443 --<< ,r:0
[10-18 15:54:19 TUYA D][iot_httpc.c:582] Decode Rev:{"t":1697615659,"success":false,"errorCode":"UUID_APPLY_FAIL","errorMsg":"UUID_APPLY_FAIL"}
[10-18 15:54:19 TUYA E][iot_httpc.c:747] errorCode:UUID_APPLY_FAIL
[10-18 15:54:19 TUYA D][tls_transporter.c:88] tls transporter close socket fd:24
[10-18 15:54:19 TUYA D][tcp_transporter.c:179] tcp transporter close socket fd:24
[10-18 15:54:19 TUYA D][tls_transporter.c:93] tls transporter close tls handler:0x7f60002320
[10-18 15:54:19 TUYA D][tuya_tls.c:1793] TUYA_TLS Disconnect ENTER
[10-18 15:54:19 TUYA D][tuya_tls.c:1843] TUYA_TLS Disconnect Success
[10-18 15:54:19 TUYA E][iot_httpc.c:912] Post Data Return Fail.-4378
[10-18 15:54:19 TUYA E][subdev_bind.c:616] dev bind err:-4378
[10-18 15:54:19 TUYA D][mg_sub_dev_managed.c:101] mg_dev_bind_cb <><><><><><><><> result:-4378
MobaXterm_192.168.5.118_20231018_160340.txt
(943.46 KiB) Downloaded 433 times
luoji
Re: 【求助】【中控】【TuyaOS SDK】子设备绑定的时候返回OPRT_SVC_HTTP_SERV_VRFY_FAIL
这个子设备不是涂鸦的。需购买子设备的授权码才能接入涂鸦云https://iot.tuya.com/pmg/license
