【已处理】【中控】【TuyaOS SDK】app控制一会后无法进入__dev_cmd_obj_cb回调函数
wyh
1) 开发包全称:SoC/Rockchip/Linux/Rockchip_rk3308_3.5.2
2) 问题现象:无法进入obj db数据回调
3) 操作流程:有线配网
[10-16 10:40:53 TUYA D][mg_tls_protocol_analysis.c:141] __mg_cp2001_ctrl cmd->cid: 16fbffffffffffff
[10-16 10:40:53 TUYA D][mg_tls_protocol_analysis.c:143] did: 16fbffffffffffff
[10-16 10:40:53 TUYA D][mg_tls_protocol_analysis.c:145] dpid: 20
[10-16 10:40:53 TUYA D][mg_tls_protocol_analysis.c:163] cmd_data: 01
[10-16 10:40:53 TUYA D][mg_tls_protocol_analysis.c:131] ctrl data:{"sId":5,"infoType":3001,"sn":4210,"dId":"16fbffffffff01ff","dCmd":"01"}
[10-16 10:40:53 TUYA D][smart_frame.c:3526] rept chan:3
[10-16 10:40:53 TUYA D][smart_frame.c:403] dp<20> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0
[10-16 10:40:53 TUYA D][smart_frame.c:407] dp_cntl bool:1, dp_data bool:0
[10-16 10:40:53 TUYA D][smart_frame.c:505] is_need_update:1, is_dp_passive:0
[10-16 10:40:53 TUYA D][smart_frame.c:2288] dp rept_type:0, data:{"20":false}
[10-16 10:40:53 TUYA D][mqc_app.c:872] Send MQTT Msg.P:4 N:59668 Q:1 Data:{"dps":{"20":false},"cid":"16fbffffffffffff"}
[10-16 10:40:53 TUYA D][scene_linkage_dp_detect.c:377] rev id:16fbffffffffffff cmd:{"20":false} type:0
[10-16 10:40:53 TUYA D][scene_linkage_dp_detect.c:393] no id match
[10-16 10:40:53 TUYA D][scene_linkage_seq_log_upload.c:161] LINKAGE | EXE_INFO | P:37 | cond detect | ERR:-13063 | [ devId:16fbffffffffffff, dp_cmd:{"20":false}, type:0 ]
[10-16 10:40:53 TUYA D][scene_linkage_dp_detect.c:377] rev id:16fbffffffffffff cmd:{"20":false} type:1
[10-16 10:40:53 TUYA D][scene_linkage_seq_log_upload.c:161] LINKAGE | EXE_INFO | P:37 | cond detect | ERR:-13063 | [ devId:16fbffffffffffff, dp_cmd:{"20":false}, type:1 ]
[10-16 10:40:53 TUYA D][tuya_lan_dp_up.c:420] local dp rpt :{"dps":{"20":false}, "cid":"16fbffffffffffff"}
[10-16 10:40:53 TUYA D][lan_pub_sub_mq_center.c:245] push topic:[LAN_DP_UP] [{"dev":"6c8693bc1b0b2dab0ca8zi", "data":{"dps":{"20":false}, "cid":"16fbffffffffffff"}}]
[10-16 10:40:53 TUYA D][lan_pub_sub_mq_center.c:288] omit node: local
[10-16 10:40:53 TUYA D][lan_pub_sub_mq.c:708] publish topic[LAN_DP_UP], [{"dev":"6c8693bc1b0b2dab0ca8zi", "data":{"dps":{"20":false}, "cid":"16fbffffffffffff"}}], 0
[10-16 10:40:53 TUYA D][lan_pub_sub_mq_api.c:154] topic publish:[{"dev":"6c8693bc1b0b2dab0ca8zi", "data":{"dps":{"20":false}, "cid":"16fbffffffffffff"}}]
[10-16 10:40:53 TUYA D][com_protocol.c:743] To:0 src:{"dps":{"20":false},"cid":"16fbffffffffffff"} pro:4 num:59668
[10-16 10:40:53 TUYA D][com_protocol.c:758] After Pack:{"protocol":4,"t":1697424053,"data":{"dps":{"20":false},"cid":"16fbffffffffffff"}} offset:82
[10-16 10:40:53 TUYA D][tuya_svc_lan.c:1032] Prepare To Send Lan:{"dps":{"20":false},"cid":"16fbffffffffffff"}, msg_len:45, out_len:97
[10-16 10:40:53 TUYA D][smart_frame.c:2044] msg_data:{"dps":{"20":false},"cid":"16fbffffffffffff"}, mqtt async dp cb:0
[10-16 10:40:53 TUYA D][smart_frame.c:221] set short dp rate rule, dpID:20, curr_t:1697424053, rept_cnt:8.
[10-16 10:40:53 TUYA D][smart_frame.c:229] set long dp rate rule, dpID:20, curr_t:1697424053, rept_cnt:0.
[10-16 10:40:53 TUYA D][smart_frame.c:238] set all dp rate rule, dpID:20, curr_t:1697424053, rept_cnt:0.
[10-16 10:40:53 TUYA D][mqtt_client.c:1482] mqtt[m2.tuyacn.com] status:7
[10-16 10:40:53 TUYA D][smart_frame.c:998] re_id:16fbffffffffffff, dpid:20, rept_num:0.
[10-16 10:40:54 TUYA D][smart_frame.c:998] re_id:16fbffffffffffff, dpid:20, rept_num:0.
[10-16 10:40:55 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:40:55 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:40:55 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:40:55 TUYA D][smart_frame.c:1141] Rev Cmd 0, data:0x34000aa0
[10-16 10:40:55 TUYA D][smart_frame.c:1425] iid:16fbffffffffffff, dpid:20, is_set_flag 1, val:1.
[10-16 10:40:55 TUYA D][mg_sub_dev_managed.c:142] dev id: 16fbffffffffffff
[10-16 10:40:55 TUYA D][mg_sub_dev_managed.c:144] dpid: 20
[10-16 10:40:55 TUYA D][mg_sub_dev_managed.c:147] dp_bool value: 1
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:239] mg_plc_dev.dev_num:6
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:241] cmd->cid:16fbffffffffffff mg_plc_dev.info.did:01fbffffffffffff
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:241] cmd->cid:16fbffffffffffff mg_plc_dev.info.did:16fbffffffffffff
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:245] ----->>>>>>>>>>>>did paie sucess<<<<<<<<<<<<<<<-----------
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:253] mg_plc_dev_ctrl:16fbffffffffffff type:0001
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:141] __mg_cp2001_ctrl cmd->cid: 16fbffffffffffff
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:143] did: 16fbffffffffffff
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:145] dpid: 20
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:163] cmd_data: 02
[10-16 10:40:55 TUYA D][mg_tls_protocol_analysis.c:131] ctrl data:{"sId":5,"infoType":3001,"sn":4362,"dId":"16fbffffffff01ff","dCmd":"02"}
[10-16 10:40:55 TUYA D][smart_frame.c:3526] rept chan:3
[10-16 10:40:55 TUYA D][smart_frame.c:403] dp<20> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0
[10-16 10:40:55 TUYA D][smart_frame.c:407] dp_cntl bool:0, dp_data bool:1
[10-16 10:40:55 TUYA D][smart_frame.c:505] is_need_update:1, is_dp_passive:0
[10-16 10:40:55 TUYA D][smart_frame.c:2288] dp rept_type:0, data:{"20":true}
[10-16 10:40:55 TUYA D][mqc_app.c:872] Send MQTT Msg.P:4 N:59669 Q:1 Data:{"dps":{"20":true},"cid":"16fbffffffffffff"}
[10-16 10:40:55 TUYA D][scene_linkage_dp_detect.c:377] rev id:16fbffffffffffff cmd:{"20":true} type:0
[10-16 10:40:55 TUYA D][scene_linkage_dp_detect.c:393] no id match
[10-16 10:40:55 TUYA D][scene_linkage_seq_log_upload.c:161] LINKAGE | EXE_INFO | P:37 | cond detect | ERR:-13063 | [ devId:16fbffffffffffff, dp_cmd:{"20":true}, type:0 ]
[10-16 10:40:55 TUYA D][scene_linkage_dp_detect.c:377] rev id:16fbffffffffffff cmd:{"20":true} type:1
[10-16 10:40:55 TUYA D][scene_linkage_seq_log_upload.c:161] LINKAGE | EXE_INFO | P:37 | cond detect | ERR:-13063 | [ devId:16fbffffffffffff, dp_cmd:{"20":true}, type:1 ]
[10-16 10:40:55 TUYA D][tuya_lan_dp_up.c:420] local dp rpt :{"dps":{"20":true}, "cid":"16fbffffffffffff"}
[10-16 10:40:55 TUYA D][lan_pub_sub_mq_center.c:245] push topic:[LAN_DP_UP] [{"dev":"6c8693bc1b0b2dab0ca8zi", "data":{"dps":{"20":true}, "cid":"16fbffffffffffff"}}]
[10-16 10:40:55 TUYA D][lan_pub_sub_mq_center.c:288] omit node: local
[10-16 10:40:55 TUYA D][lan_pub_sub_mq.c:708] publish topic[LAN_DP_UP], [{"dev":"6c8693bc1b0b2dab0ca8zi", "data":{"dps":{"20":true}, "cid":"16fbffffffffffff"}}], 0
[10-16 10:40:55 TUYA D][lan_pub_sub_mq_api.c:154] topic publish:[{"dev":"6c8693bc1b0b2dab0ca8zi", "data":{"dps":{"20":true}, "cid":"16fbffffffffffff"}}]
[10-16 10:40:55 TUYA D][com_protocol.c:743] To:0 src:{"dps":{"20":true},"cid":"16fbffffffffffff"} pro:4 num:59669
[10-16 10:40:55 TUYA D][com_protocol.c:758] After Pack:{"protocol":4,"t":1697424055,"data":{"dps":{"20":true},"cid":"16fbffffffffffff"}} offset:81
[10-16 10:40:55 TUYA D][tuya_svc_lan.c:1032] Prepare To Send Lan:{"dps":{"20":true},"cid":"16fbffffffffffff"}, msg_len:44, out_len:96
[10-16 10:40:55 TUYA D][smart_frame.c:2044] msg_data:{"dps":{"20":true},"cid":"16fbffffffffffff"}, mqtt async dp cb:0
[10-16 10:40:55 TUYA D][smart_frame.c:221] set short dp rate rule, dpID:20, curr_t:1697424055, rept_cnt:9.
[10-16 10:40:55 TUYA D][smart_frame.c:229] set long dp rate rule, dpID:20, curr_t:1697424055, rept_cnt:0.
[10-16 10:40:55 TUYA D][smart_frame.c:238] set all dp rate rule, dpID:20, curr_t:1697424055, rept_cnt:0.
[10-16 10:40:55 TUYA D][mqtt_client.c:1482] mqtt[m2.tuyacn.com] status:7
[10-16 10:40:55 TUYA D][smart_frame.c:998] re_id:16fbffffffffffff, dpid:20, rept_num:0.
[10-16 10:40:57 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:40:57 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:40:57 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:40:57 TUYA D][smart_frame.c:1141] Rev Cmd 0, data:0x34000aa0
[10-16 10:40:57 TUYA D][smart_frame.c:1425] iid:16fbffffffffffff, dpid:20, is_set_flag 1, val:0.
[10-16 10:40:57 TUYA D][mg_sub_dev_managed.c:142] dev id: 16fbffffffffffff
[10-16 10:40:57 TUYA D][mg_sub_dev_managed.c:144] dpid: 20
[10-16 10:40:57 TUYA D][mg_sub_dev_managed.c:147] dp_bool value: 0
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:239] mg_plc_dev.dev_num:6
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:241] cmd->cid:16fbffffffffffff mg_plc_dev.info.did:01fbffffffffffff
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:241] cmd->cid:16fbffffffffffff mg_plc_dev.info.did:16fbffffffffffff
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:245] ----->>>>>>>>>>>>did paie sucess<<<<<<<<<<<<<<<-----------
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:253] mg_plc_dev_ctrl:16fbffffffffffff type:0001
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:141] __mg_cp2001_ctrl cmd->cid: 16fbffffffffffff
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:143] did: 16fbffffffffffff
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:145] dpid: 20
[10-16 10:40:57 TUYA D][mg_tls_protocol_analysis.c:163] cmd_data: 01
[10-16 10:40:59 TUYA D][scene_linkage_rule_sync.c:1787] update all 0
[10-16 10:40:59 TUYA D][thread_pool_temp.c:728] temp run add 0x7f7401b330 0x552a78 60444c
[10-16 10:40:59 TUYA D][thread_pool_temp.c:634] temp run 0x552a78 60444c
[10-16 10:40:59 TUYA D][scene_linkage_rule_sync.c:1787] update all 1
[10-16 10:40:59 TUYA D][thread_pool_temp.c:728] temp run add 0x7f7401b330 0x552a78 604450
[10-16 10:40:59 TUYA D][thread_pool_temp.c:634] temp run 0x552a78 604450
[10-16 10:40:59 TUYA D][thread_pool_temp.c:202] run temp 0x552a78 60444c in thread 2851d500 BEGIN
[10-16 10:40:59 TUYA D][scene_linkage_rule_sync.c:1550] tmm_update_scene_lnkage_cb, rule_type:0
[10-16 10:40:59 TUYA D][iot_httpc.c:894] Post Data: {"devId":"6c8693bc1b0b2dab0ca8zi","linkageType":1,"t":1697424059}
[10-16 10:40:59 TUYA D][iot_httpc.c:906] Post URL: https://a2.tuyacn.com/d.json?a=tuya.dev ... 655544c346
[10-16 10:40:59 TUYA D][uni_network.c:313] unw_gethostbyname a2.tuyacn.com, prio 2
[10-16 10:40:59 TUYA D][uni_network.c:352] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com
[10-16 10:40:59 TUYA D][tcp_transporter.c:81] bind ip:c0a8056a port:0 ok
[10-16 10:41:00 TUYA D][tuya_tls.c:1390] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[10-16 10:41:00 TUYA D][tuya_tls.c:1429] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE
[10-16 10:41:00 TUYA D][tuya_tls.c:1497] load tuya cert.
[10-16 10:41:00 TUYA D][tuya_tls.c:1502] parse crt <0> len <2002> ret <0>
[10-16 10:41:00 TUYA D][tuya_tls.c:1502] parse crt <1> len <1028> ret <0>
[10-16 10:41:00 TUYA D][tuya_iot_com_api.c:254] tuya public url
[10-16 10:41:00 TUYA D][tuya_tls.c:1614] socket fd is set. set to inner send/recv to handshake
[10-16 10:41:00 TUYA D][tuya_tls.c:1674] handshake finish for a2.tuyacn.com. set send/recv to user set
[10-16 10:41:00 TUYA D][tuya_tls.c:1683] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[10-16 10:41:00 TUYA D][httpc.c:641] Connect: a2.tuyacn.com Port: 443 --<< ,r:0
[10-16 10:41:00 TUYA D][iot_httpc.c:582] Decode Rev:{"result":[],"t":1697424060,"success":true}
[10-16 10:41:00 TUYA D][tls_transporter.c:88] tls transporter close socket fd:23
[10-16 10:41:00 TUYA D][tcp_transporter.c:179] tcp transporter close socket fd:23
[10-16 10:41:00 TUYA D][tls_transporter.c:93] tls transporter close tls handler:0x7f60003110
[10-16 10:41:00 TUYA D][tuya_tls.c:1793] TUYA_TLS Disconnect ENTER
[10-16 10:41:00 TUYA D][tuya_tls.c:1843] TUYA_TLS Disconnect Success
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:1601] get linkage totalcnt:0
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:1603] No Rule In Server
[10-16 10:41:00 TUYA D][scene_linkage_rule_exe.c:895] scene_linkage_rule_delete_all, rule_type[0]
[10-16 10:41:00 TUYA D][scene_linkage_storage.c:678] no record now
[10-16 10:41:00 TUYA D][scene_linkage_storage.c:685] ruleID removeAll type:0 ret:0
[10-16 10:41:00 TUYA D][scene_linkage_scene_name.c:345] remove all name
[10-16 10:41:00 TUYA D][scene_linkage_scene_name.c:350] name list is empty
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:494] read __get_real_count_from_nvram rule_type:0 real_cnt:0
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:505] No rules.
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:363] update ruleId len:2, ruleid:[].
[10-16 10:41:00 TUYA D][thread_pool_temp.c:728] temp run add 0x7f7401b330 0x552140 0
[10-16 10:41:00 TUYA D][thread_pool_temp.c:634] temp run 0x552140 0
[10-16 10:41:00 TUYA D][thread_pool_temp.c:205] thread 2851d500 END
[10-16 10:41:00 TUYA N][gw_uni_msg_queue.c:286] last_cb:0x4fd5e8
[10-16 10:41:00 TUYA D][thread_pool_temp.c:219] num:3 to exe
[10-16 10:41:00 TUYA D][thread_pool_temp.c:202] run temp 0x552a78 604450 in thread 2851d500 BEGIN
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:1550] tmm_update_scene_lnkage_cb, rule_type:1
[10-16 10:41:00 TUYA D][iot_httpc.c:894] Post Data: {"devId":"6c8693bc1b0b2dab0ca8zi","linkageType":2,"t":1697424060}
[10-16 10:41:00 TUYA D][iot_httpc.c:906] Post URL: https://a2.tuyacn.com/d.json?a=tuya.dev ... d223e27152
[10-16 10:41:00 TUYA D][uni_network.c:313] unw_gethostbyname a2.tuyacn.com, prio 2
[10-16 10:41:00 TUYA D][uni_network.c:352] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com
[10-16 10:41:00 TUYA D][tcp_transporter.c:81] bind ip:c0a8056a port:0 ok
[10-16 10:41:00 TUYA D][scene_linkage_rule_exe.c:895] scene_linkage_rule_delete_all, rule_type[1]
[10-16 10:41:00 TUYA D][scene_linkage_storage.c:685] ruleID removeAll type:1 ret:0
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:494] read __get_real_count_from_nvram rule_type:1 real_cnt:0
[10-16 10:41:00 TUYA D][thread_pool_temp.c:202] run temp 0x552140 0 in thread 2851d500 BEGIN
[10-16 10:41:00 TUYA D][iot_httpc.c:894] Post Data: {"devId":"6c8693bc1b0b2dab0ca8zi","linkageType":1,"successList":[],"t":1697424060}
[10-16 10:41:00 TUYA D][iot_httpc.c:906] Post URL: https://a2.tuyacn.com/d.json?a=tuya.dev ... 8412c6ca6a
[10-16 10:41:00 TUYA D][scene_linkage_rule_exe.c:838] __rule_delete_all, rule_type[0]
[10-16 10:41:00 TUYA D][scene_linkage_rule_exe.c:841] no record now
[10-16 10:41:00 TUYA I][scene_linkage_scene_name.c:499] scene_linkage_name_id_update_notify
[10-16 10:41:00 TUYA D][scene_linkage_rule_exe.c:838] __rule_delete_all, rule_type[1]
[10-16 10:41:00 TUYA D][iot_httpc.c:582] Decode Rev:{"result":true,"t":1697424060,"success":true}
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:1123] gw update linkage rule localize success. 0
[10-16 10:41:00 TUYA D][iot_httpc.c:894] Post Data: {"devId":"6c8693bc1b0b2dab0ca8zi","linkageType":2,"successList":[],"t":1697424060}
[10-16 10:41:00 TUYA D][scene_linkage_rule_sync.c:1123] gw update linkage rule localize success. 1
[10-16 10:41:00 TUYA D][thread_pool_temp.c:219] num:2 to exe
[10-16 10:41:00 TUYA D][thread_pool_temp.c:148] put thread 0x7f7401b330
[10-16 10:41:00 TUYA D][thread_pool_temp.c:156] temp thread total:3 used:0
[10-16 10:41:02 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:02 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:02 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:07 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:07 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:07 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:09 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:09 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:09 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:10 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:10 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:10 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:11 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:11 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:11 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:12 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:12 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:12 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:13 TUYA D][tuya_svc_lan.c:1654] fd:22, wk_stat = 2, type = 7
[10-16 10:41:13 TUYA D][tuya_svc_lan.c:268] type:0x7
[10-16 10:41:13 TUYA D][tuya_svc_lan.c:1148] Rev TP CMD. Send to User,Lan Ver 3.5
[10-16 10:41:39 TUYA D][simplekv.c:128] <tmm_backup_work> backup file start...time: 3160, MsTime: 292
[10-16 10:41:39 TUYA D][simplekv.c:240] backup normal file to bak success
[10-16 10:41:39 TUYA D][simplekv.c:131] <
tmm_backup_work> backup file end...time: 3160, MsTime: 293
wyh
Re: 【求助】【中控】【TuyaOS SDK】app控制一会后无法进入__dev_cmd_obj_cb回调函数
过2min后网关和设备都离线 了
luoji
提供下涂鸦给的原始sdk包名称。我看这个调试设备的pid对应的涂鸦方案是网关,并不是中控
wyh
使用vscode ide里面直接生成的SoC/Rockchip/Linux/Rockchip_rk3308_3.5.2 rk3308的3.5.2版本
wyh
开发包名称:tuyaos-gw-integrated_5.0.4_rk3308_wifi-cc-tpp01z_0.1.11
大佬们有知道为啥的吗?
现在一直是这样,进不去回调
MobaXterm_192.168.5.118_20231019_161933.txt
(2.22 MiB) Downloaded 401 times
luoji
使用sdk带的demo测一下回调是否有打印
