【技术干货】TuyaOS(NB-IoT)新平台移植指导:适配tkl_nbiot_psm.c
liujt@tuya.com
本章介绍对tkl_nbiot_psm.c的接口相关适配
  • 平台psm配置相关
    • Code: Select all
       * @brief Set config about the paltform
       * @return OPERATE_RET OPRT_OK: success others: fail
      OPERATE_RET tkl_nbiot_psm_plat_config(VOID)
          // --- BEGIN: user implements ---
          return OPRT_NOT_SUPPORTED;
          // --- END: user implements ---
      对于PSM相关初始化无特殊操作,直接返回OPRT_OK
    • Code: Select all
       * @brief Regist the PSM sleep notify cb
       * @param cb notify callback function
      OPERATE_RET tkl_nbiot_psm_sleep_notify_reg(TKL_NB_PSM_NOTIFY_CB_T cb)
      系统睡眠事件通知回调注册(设备睡眠前需要将各种睡眠类型通过回调cb通知SDK)
    • Code: Select all
       * @brief Specify a pin for wakeup trigger
       * @param pin_num  @ref TKL_GPIO_NAME_E
       * @param wakeup_cb call back funtion
       * @return OPERATE_RET OPRT_OK: success others: failed
      OPERATE_RET tkl_nbiot_psm_wakeup_pin_cfg(INT_T pin_num, TKL_NB_WAKEUP_CB wakeup_cb)
      PSM外部硬件唤醒脚及唤醒后回调函数注册
  • 睡眠锁操作
    • Code: Select all
       * @brief Create a psm manager lock
       * @param lock_name name of the lock
       * @param handle sleeplock handle
      OPERATE_RET tkl_nbiot_psm_create_sleeplock(CONST PCHAR_T lock_name, UCHAR_T *handle)
      创建睡眠锁
    • Code: Select all
       * @brief Acquire the sleeplock, keep awake
      OPERATE_RET tkl_nbiot_psm_acquire_sleeplock(UCHAR_T handle)
      睡眠锁定(禁止系统进入睡眠)
    • Code: Select all
       * @brief Release the sleeplock, allow psm
      OPERATE_RET tkl_nbiot_psm_release_sleeplock(UCHAR_T handle)
      睡眠锁释放(允许系统进入睡眠)
  • 睡眠操作相关
    • Code: Select all
       * @brief Force enter psm mode
       * @return VOID
      VOID tkl_nbiot_psm_force_sleep(VOID)
          return ;
      强制睡眠(立即进入睡眠)
    • Code: Select all
       * @brief Get the power on reason
       * @param result powerson reason
      OPERATE_RET tkl_nbiot_psm_get_poweron_result(TKL_NB_POWER_ON_RESULT_E *result)
      获取系统从何种状态醒来(上电启动/睡眠/系统复位/看门狗复位等)
    • Code: Select all
       * @brief Get the wake up reason
       * @param src wakeup reason reason
      OPERATE_RET tkl_nbiot_psm_get_wakeup_source(TKL_NB_WAKEUP_SOURCE_E *src)
      获取系统被何种唤醒源唤醒(上电唤醒/RTC定时唤醒/PSM按键唤醒)
  • 睡眠定时器相关操作
    • Code: Select all
       * @brief Create rtc timer
       * @param time_period_sec time period of the timer
       * @param is_periodic if the timer is perodic
       * @param cb timer callback
      OPERATE_RET tkl_nbiot_psm_rtc_timer_create(UINT_T time_period_sec, BOOL_T is_periodic,TKL_NB_SLP_TIMER_CB_T cb)
      创建睡眠定时器
    • Code: Select all
       * @brief Start a rtc timer
       * @param null
      OPERATE_RET tkl_nbiot_psm_rtc_timer_start(VOID)
      启动睡眠定时器
    • Code: Select all
       * @brief Stop rtc timer
       * @param null
      OPERATE_RET tkl_nbiot_psm_rtc_timer_stop(VOID)
      停止睡眠定时器
    • Code: Select all
       * @brief Del rtc timer
       * @param null
      OPERATE_RET tkl_nbiot_psm_rtc_timer_delete(VOID)
      删除睡眠定时器
  • 其他
    • Code: Select all
       * @brief Check the usb is active
       * @return BOOL_T true: active false: not active
      BOOL_T tkl_nbiot_psm_usb_is_active(VOID)
          return false;
      返回USB是否处于激活状态,系统无USB直接返回false.
