ThingSmartMatterExtensionKits
spoxpro
I'm try to discover a matter gateway the auto magic method. I have this working on android. I've followed the instructions in the documentation for matter pairing in the iOS section.
I have added the pods to my pod file
pod "ThingSmartCryption", :path =>'./'
pod 'ThingSmartHomeKit', '~> 5.1.0'
pod "ThingSmartMatterExtensionKit"
and done pod update, pod install, numerous times.
I can import all the modules from ThingSmartHomeKit, but it won't import ThingSmartMatterExtensionKits
import ThingSmartMatterExtensionKits <== No such module 'ThingSmartMatterExtensionKits'
import ThingSmartHomeKit
import ThingSmartBLEKit
import ThingSmartActivatorKit
Which means I can't use the
ThingSmartMatterDiscoveryActivator.sharedInstance().startDiscovery()
to start discovery.
ThingSmartMatterExtensionKit has installed fine, it installed v0.1.1. I see it in the Pods folder along with all the others. It contains the Frameworks and Supporting Files folders which has the framework and platform files.
How do I fix ' No such module 'ThingSmartMatterExtensionKits'
huangdaxia
Re: ThingSmartMatterExtensionKits
please use pod "ThingSmartMatterExtensionKit", '5.0.5'
and run pod update ThingSmartMatterExtensionKit --repo-update
spoxpro
Thank you for your reply. I have installed ThingSmartMatterExtensionKit", ‘5.0.5’.
Follow the instructions given here
https://developer.tuya.com/en/docs/app- ... 5ei0oqryag
Im am still getting errors for both methods of pairing :-
ThingSmartMatterActivator.sharedInstance().parseSetupCode("code”)
=> ThingSmartMatterActivator has no method parseSetupCode
and
=> Cannot find ThingSmartMatterDiscoveryActivator in scope
I have imported both ThingSmartMatterExtensionKit and ThingSmartMatterKit. If I search the pod files I can't find parseSetupCode nor ThingSmartMatterDiscoveryActivator.
Is there a newer version of ThingSmartMatterKit ? I currently have 4.5.10.
huangdaxia
We apologize for any inconvenience this may have caused.
please use pod "ThingSmartMatterKit", '5.2.8' and run pod update ThingSmartMatterKit --repo-update
spoxpro
thanks
