【已解决】【TuyaOS SDK】tuya mqtt上线后,程序执行段错误的问题
19926824531
(1)扫码
int ret = tuya_ipc_direct_connect(pDataBuf, TUYA_IPC_DIRECT_CONNECT_QRCODE);
(2)tkl_wifi建立sta
OPERATE_RET tkl_wifi_station_connect(CONST SCHAR_T *ssid, CONST SCHAR_T *passwd)
	CHECK_RTNP(!ssid || !passwd, OPRT_INVALID_PARM, "%s => input error!!!\n", __FUNCTION__);
WF_STATION_STAT_E cur_WifiStaState = (WF_STATION_STAT_E)tuya_wifi_get_StationState();
if(WSS_IDLE != cur_WifiStaState && WSS_PASSWD_WRONG != cur_WifiStaState &&
	WSS_NO_AP_FOUND != cur_WifiStaState && WSS_CONN_FAIL != cur_WifiStaState)
	DBG("%s => wpa is running, do nothing!!! cur_WifiStaState: %d\n", __FUNCTION__, cur_WifiStaState);
	return OPRT_OK;
if(strcmp((char*)ssid, g_app_config.wlan_ssid) || (strcmp((char*)passwd, g_app_config.wlan_key)) )
	strncpy(g_app_config.wlan_ssid, (char*)ssid, WIFI_SSID_LEN);
	strncpy(g_app_config.wlan_key, (char*)passwd, WIFI_PASSWD_LEN);
	save_app_config();
DBG("%s => ssid:%s, passwd:%s\n", __FUNCTION__, (char*)ssid, (char*)passwd);
EasyCamMsgInfo msg = {0};
msg.cmdId = NET_TASK_MSG_ID_CONNECT_TO_AP;
post_net_task_msg( &msg );
tuya_wifi_set_sta_conn_flag(1);
return OPRT_OK;
(3) 连接过程中上报状态
			WF_EVENT_E wf_event = WFE_CONNECTED;
		if(state == WSS_CONN_FAIL)
			wf_event = WFE_CONNECT_FAILED;
		else if(state == WSS_GOT_IP || state == WSS_CONN_SUCCESS)
		else
			wf_event = WFE_DISCONNECTED;
		if(tuya_sdk_wifi_status_cb) tuya_sdk_wifi_status_cb(wf_event, NULL);
(4)sdk状态回调
VOID tuya_ipc_status_changed_cb(IN TUYA_IPC_STATUS_GROUP_E changed_group, IN CONST TUYA_IPC_STATUS_E status[TUYA_IPC_STATUS_GROUP_MAX])
	TUYA_IPC_STATUS_E cur_status = status[changed_group];
	INT_T i = 0;
	DBG("status chaged: group[%d] status[%d]\n", changed_group, cur_status);
if(0 == access("/mnt/mtd/config/zw_mqtt_debug.flag", 0))
	if(TUYA_IPC_STATUS_ONLINE == cur_status)
		DBG("------mqtt online------\n");
		sleep(10);
		DBG("------mqtt online cb out------\n");
return ;
pippin-bobo
Re: 【求助】【TuyaOS SDK】tuya mqtt上线后,程序执行段错误的问题
1)没有看到附件
2)tkl_wifi如果没有修改不用回传,如果能入网这部分应该没问题
3)主业务流程代码(demo里面的app_main)可以提供我们看一下
19926824531
论坛好像只能上传代码片段
19926824531
以下是tuya主业务流程,入口是initTuyaService,帮忙看下流程是否正确
pippin-bobo
添加附件不行?
19926824531
只要是代码文件,报HTTP error.
重命名为txt都不行
pippin-bobo
附件压缩包可行吗?
19926824531
应该可以的
pippin-bobo
pippin-bobo 2024年 Jan 16日 15:33
1)没有看到附件
tkl主要是你们根据平台来确认,我只能帮你分析下3)部分,是不是接入有错误
19926824531
Notes:
(1) 设备可以联网上线,tkl_wifi应该没问题。
(2) 主业务流程代码入口是: initTuyaService
(3) sdk状态回调:tuya_ipc_status_changed_cb
