mmWave Sensors Not Exposed and Scene Control Not Working Properly in Smartthings.
unnamedi
Okay, it's working properly now!
Now I have two Scene controls that apparently aren't working properly!
Virtual ID: ebb8ecd69eda84b933p1yr
Virtual ID: eb1804cbae3b46b1eeux23
It seems that Via Matter isn't reporting double-clicks. It's only recognizing single presses!
And in SmartThings, each button has many options that the control itself doesn't have, such as pressing 3, 4, or even 6 times! It toggles up or down with each button!
fangping.guo
Re: mmWave Sensors Not Exposed and Scene Control Not Working Properly in Smartthings.
Hello, regarding this programmable switch, could you try it on Home Assistant? We're not sure if this is an issue specific to the Samsung platform.
unnamedi
The same thing happens with Home Assistant! It only recognizes pressing once and holding it down. It doesn't recognize pressing twice!
I believe it's something with Tuya. I used these devices on iHost, and they were exported correctly via Matter.
I migrated to the Tuya Hub to see if I could fix this issue!
unnamedi
Hi, I just realized that the device with virtualid: eb35685daab86c2f14ecmm is not working with the dimmer function. If I change it via matter, the dimmer doesn't change.
