mmWave Sensors Not Exposed and Scene Control Not Working Properly in Smartthings.
unnamedi
Hello, I just purchased a Novadigital hub that has the Matter and Thread function and works as a bridge.
I just noticed that the Novadigital MMWAVE sensor is not exported via Matter.
Model: ZTS-MM
Virtual ID: eb2727d37719a0ab04do6c
I just noticed that the scene control is not working properly in Smartthings; it simply does not receive the information when we press the buttons. However, I noticed that in Home Assistant the commands are not reported correctly. It does not identify double taps..
Model: SYT-ZB
Virtual ID: eb3f462d2cfc4a3c810hqq
The same thing happens with this other 1-channel Scene Button in Smartthings; it does not receive the information, I noticed that in Home Assistant the commands are not reported correctly. It does not identify double taps.!
Virtual ID: ebf79d3c849ed89bbe7nwt
I just noticed that a Motion sensor is not reporting battery and Motion status correctly via matter.
Virtual ID: eba5029e4e83fa7476deza
I just paired a Door and Window sensor that works correctly but the battery status is incorrect.
Virtual ID: ebea31315a9d9d43a6zdlh
huangxh
Re: mmWave Sensors Not Exposed and Scene Control Not Working Properly in Smartthings.
unnamedi 2025年 Jun 5日 13:04
Model: ZTS-MM
Model: SYT-ZB
Pls update the gateway to version 1.13.6. Then delete those devices with issues, add them again, and test it.Thank you!!
unnamedi
Hello, I updated the HUB and with that the Motion sensor started reporting the battery correctly, but it is not informing when there is Movement in SmartThings or in Home Assistant.
Virtual ID: eb63388ca6dc96ac92a3ka
EDIT: 07/06/2025
After connecting it to the HUB again, I noticed that the battery stopped working!
In short, it doesn't work properly!
The MMWAVE sensor started working properly!
However, for some reason, it is reporting a battery when it is not the Battery
Model: ZTS-MM
The Scene control is not working properly, but it still works the same!
Model: SYT-ZB
The Door and Window sensor is now working correctly!
unnamedi
fangping.guo
Hi, we have updated the object model files for the 【Motion sensor】 device.
Please unpair the devices and re-pair them to test, and we welcome your continued feedback.
unnamedi
Hello, I just tested and the sensor is exported via Matter, but it does not show the correct status; it never reports movement. It always shows no movement. The virtual ID eb63388ca6dc96ac92a3ka
fangping.guo
Hello, I have once again corrected the use of the proper DP mapping. Please restart the gateway for testing. Thank you.
unnamedi
Wow, it seems to be working properly now! Thank you very much, I'll run more tests!
One thing I noticed: I installed a new temperature sensor with a screen, and it's not being exported by Matter. I just noticed it now!
Virtual ID: eb3b790d3011036f1fedyz
This is the link to buy it on a digital platform here in the country where I live.
https://shopee.com.br/product/123229993 ... dpbG1vd0Jn WlZ0VmFEZDlYQTdhM29JV2hyUnJwOUlNajRicDlRPT0&gad_source=1&gad_campaignid=21445281076&gbraid=0AAAAACoEtRnXg5R-z3K_ CW5YgHNJpgJWc&gclid=Cj0KCQjw8eTFBhCXARIsAIkiuOxNuc4ZLsrCkU887zlT4JYRHlJEXQ1lN2DkBBNQ75YHuiSIbB2dq1IaAlY_EALw_wcB
fangping.guo
Hi, I have updated the object model files for the temperature sensor device.
Please reboot the gateway and test.
unnamedi
I saw that it started working, thank you very much. I'll get some new sensors and test them to see if they export correctly.
