mmWave Sensors Not Exposed and Scene Control Not Working Properly in Smartthings.
Eternal
this update was pushed to my gateway and now 3 of my sensors keep randomly going from present to none when someone is in the area. They are completely unusable now. It is doing it natively in the smartlife app. I have reset them and readded them and it still goes crazy flooding the log with presence and none when someone is in the room.
ebc24b306ef4b19d27kf0z
ebbb426fbc8b88957cxfh6
eb7b0ff66d3a22718ftgqj
unnamedi
Re: mmWave Sensors Not Exposed and Scene Control Not Working Properly in Smartthings.
fangping.guo 2025年 Sep 5日 14:49
Hi, I have updated the object model files for the temperature sensor device.
Please reboot the gateway and test.
Hello, how are you? I have a Dimmer configured with its Virtual ID: eb35685daab86c2f14ecmm, but it seems that it is not being exported to the matter bridge.
fangping.guo
Hello, I have configured the conversion file for the device corresponding to eb35685daab86c2f14ecmm. Please restart the gateway for testing.
Regarding the sensor anomalies detected in devices like ebc24b306ef4b19d27kf0z, could you test the device in a relatively clean and open environment? The configuration file I set up only affects bridging to Matter functionality and should not cause frequent reporting in the Tuya app.
unnamedi
fangping.guo 2025年 Sep 11日 10:03
Well, this device is not mine, it belongs to another user. I also found the report about the change strange, since here only changes are made to the Matter bridge.
unnamedi
Regarding this, it is working correctly now it was exported correctly and the dimmer function is correct. Today another device arrived and if anything happens I will inform you.
unnamedi
Hello, a two-channel dimmer arrived and only one channel is working, both are exported, but only one works to turn on and off, the other channel does not respond to commands. Virtual ID: eb6885b967cda3fdfcakgp
fangping.guo
Done. Please restart the gateway for testing.
unnamedi
fangping.guo 2025年 Sep 12日 09:38
Thank you very much the error seems to have been fixed.
Edit:
It seems that it is not responding correctly to the shutdown command. If it is off and I tell it to turn on, it turns on, but it is not turning off the channel that had the problem before. Another thing I noticed is that the brightness intensity is not passed on that channel.
The channel that is having a problem is channel 1. It is not responding correctly to commands and is not even bringing up brightness.
Edit2:
It seems that the error is only in Smartthings, it is not responding correctly. Home Assistant seems to be working correctly!
unnamedi
I just realized that I have a socket with two inputs and one USB A input and another USB C. That for some reason is only exporting as if it were 1 socket. I have another one like that configured and it exports 4 entities to matter.
IDVIRTUAL: eb4847c7bf88c44714lzao
fangping.guo
Hello, I've updated the conversion file for device eb4847c7bf88c44714lzao. It should now be named “4 Gang Switch.” Please restart the gateway to test.
