[Support] - Curtain Switch
brunojni
Hi everyone,
I`m seeking support for a Moes Curtain Switch (id: eb318a6ca7d988a4a7rf39) that is paired to my M6 Hub and shared via Matter with two other platforms.
First problem is that the open and stop commands are swapped in the other plataforms, i.e.: I need to click stop in order to open the curtain.
Second problem is more annoying, the relay goes offline anda just come back with cycle powering, not even the repair button works.
Hope someone can help me.
Thanks in advance,
Bruno
fangping.guo
Re: [Support] - Curtain Switch
hello,the window coveing bridge file updated,please reboot and retest.
what is the relay device id?
brunojni
Thank you for the quick fix on the command issue.
The device ID is eb318a6ca7d988a4a7rf39. Any guess on why is going offline out of nowhere?
brunojni
Hi, Zigbee connection has dropped again and only power cycle fixed. Should I transfer this topic to another sub-forum?
