Generic Scene Switch
Sugar
Single, double and long press button. Generic switch. Single Button. It's exposed, but not working.
Button Virtual id: bffb42c510aceee3a7lecn
Triple Scene Switch:
Single, double and long press. It's exposed, but not working.
Virtual ID: bf02bbf9376b905655vpu5
Another triple Scene Switch:
Virtual ID: bf7faf9d5de46d95e0zofp
If possible to add/fix
Thank you.
fangping.guo
Re: Generic Scene Switch
Hello, I have made changes to the bridge configuration on the cloud. You can restart your Matter gateway and wait for a few minutes before testing again.
Sugar
fangping.guo 2026年 Jan 22日 17:33
Hello, hello.
How did you expose them?
I will ask again on Aqara why it's still not working :D
Thank you.
Edit:
Topic here: https://forum.aqara.com/t/need-help-wit ... hes/215430
Edit 2: I just added the IKEA BILRESA dual button to the Moes Matter Controller, then Moes Matter Bridge exposed it correctly to the Aqara app, but it's the same situation as with the Zigbee button, presses won't be registered in Aqara.
If IKEA is directly paired with their matter controller it's working correctly.
Virtual ID of that IKEA BILRESA dual button Matter over Thread device is: bf67a2ghxcourbp6
Sugar
Any update on that? Thanks :)
fangping.guo
From the log 2026-01-29 00:07:01:915 GMT +00:00, I can see that when you click the third button of the device ID: bf7faf9d5de46d95e0zofp, the Tuya Gateway generates three Matter events and corresponding parameters:
  1. GenericSwitchOnInitialPress, newPosition=1;
  2. GenericSwitchOnShortRelease, previousPosition=1;
  3. GenericSwitchMultiPressComplete, PreviousPosition=0, TotalNumberOfPressesCounted=1;
I believe the events we sent are correct. Could you please inquire with Aqara whether they think there are any abnormalities in the events we sent? In their opinion, what events and parameters should be triggered by a single click, a double click, and a long press? If they could clarify the specific expectations for the different behaviors of the generic switch device type, I would be willing to make the necessary modifications.
Sugar
fangping.guo 2026年 Jan 29日 10:14
Specification is the same for previous matter versions. For true, I don't understand everything here.
If it is not helpful, I have sent an email directly to Aqara support and asked them if they can share an example of how they exposed their Zigbee buttons with their Matter Bridge. I will attach the answer when it arrives.
fangping.guo
For the device you are using, the value of the featuremap for the switch cluster that we have declared is 30 (0x1E), which means that bits 1, 2, 3, and 4 are enabled while bits 0 and 5 are not. Correspondingly, we will generate event IDs 1, 2, 3, 4, 5, and 6.
Sugar
fangping.guo 2026年 Jan 30日 09:35
Did you change something? Long press is working correctly for all these buttons now, only single and double press is not working.
Video:
fangping.guo
No, I didn't make any changes. I merely view our configuration and informed you of our reporting status.
Sugar
fangping.guo 2026年 Feb 2日 09:22
Aqara support asked if you could share parameters for single press, double press, and long press, so they can check it better.
Same as here, if I assume correctly, here is for a single press, yes?
They asked as well if you have confirmations that it is working with any other matter platforms, for single and double press, since long press is working correctly. It doesn't have to be that particular switch from that topic; if you have confirmation of any other switches that support single, double, and long presses working with 3rd party matter controllers.
Let's use that switch for single, double and long press parameters. device ID: bffb42c510aceee3a7lecn
I pressed that switch to create logs at 22:10 on 08.02.2026 UK TIME ZONE.
Thank you.
