Relay not exposed by matter bridge
Sugar
Moe's Hub Virtual ID: bfdd385cadc34fdb76jlx7
Relay Virtual ID: bfeb311cf603f2191dc4mc
Thank you if possible to add it.
https://a.aliexpress.com/_EubrFRq
fangping.guo
Re: Relay not exposed by matter bridge
Hello, I have completed the support for the new matter bridging function of this device. Please restart the gateway for testing.
Sugar
fangping.guo 2025年 Nov 25日 13:46
Hi. It's still not exposed. If you can check it. Thanks.
fangping.guo
Hello, please provide the following information to help us troubleshoot the issue:
  1. Your target smart home ecosystem (Apple, Google, Home Assistant, etc.)
  2. A screen recording demonstrating your steps, including the gateway and device status within the Tuya ecosystem, as well as the process of sharing the gateway to the target ecosystem (using the English interface)
  3. A written description of your expected outcome and the actual result
Sugar
If you could expose on and off plus relay status after power outage (if it's supported for matter with tuya platform).
video of device:
video of me sharing Moe's hub to the aqara platform, and as you can see device is not there {
(that on off plugs are different devices, for clarification):
Expected result: being able to turn on/off switch and set up the relay status after power outage.
Target app is Aqara app with Aqara matter controller.
Thank you.
