Virtual ID of Moes Hub is: bfdd385cadc34fdb76jlx7
Tapo T310 Temperature Sensor:
Virtual ID for T310 (Temperature) is bfb5cf5519cd2571f3h5yc
You can't add those child devices to the main screen or change the name.
It is dp_temperature instead of just Temperature.
Tapo T315 Temperature Sensor:
Virtual ID for T315 (Temperature) is: bf649b287424409932xcbr
That sensor is wrongly named; it should be Tapo T315 Temperature instead of T310. T310 is a different version of their temperature and humidity sensor (version without a screen).
Tapo 315 Humidity Sensor:
Virtual ID for T315 (Humidity) is: bf735ce333eac34bc64pqz
That sensor is wrongly named; it should be Tapo T315 Humidity instead of Matter product 2.
Tapo T310 Humidity Sensor:
Virtual ID for T310 (Humidity) is: bffebcbc4ed71e3dc82jw6
That sensor is wrongly named; it should be Tapo T310 Humidity instead of Matter product 3.
Thank you if possible to fix it ![]()
