Issues with Zemismart M6 Hub exposing Thermostatic Radiator Valve to Apple HomeKit
kafarek
I am experiencing issues with my Zemismart M6 Hub gateway and its connected Zigbee Thermostatic Radiator Valve in Apple HomeKit.
First I have added Gateway to SmartLife App, then I have added it to Apple HomeKit using "Share via Matter Gateway" option.
Then I added the valve to gateway as sub-device in SmartLife App and then it exposed itself automatically to Apple Homekit.
Valve is working in SmartLife App as expected.
But in Apple HomeKit shows only current temperature from Thermostatic Radiator Valve. I cannot set the desired temperature (manual mode), set the work mode (on/off/manual/auto) or check the battery level. Also the device shows as not responding (On screenshots: "Brak odp." or "Akcesorium nie odpowiada" = "Device is not responding").
Gateway details:
Virtual ID: bfdf75c96ee0c4d9777kq5
Main module version: 1.1.30
Zigbee Thermostatic Radiator Valve details:
Virtual ID: bf8dad0ac65cd7df17jdar
Thank you in advance for your assistance.
fangping.guo
Re: Issues with Zemismart M6 Hub exposing Thermostatic Radiator Valve to Apple HomeKit
Based on the device conversion files, I don't see any configuration errors. Have you tried bridging the devices to other Matter platforms for testing, such as Home Assistant (HA)?
kafarek
Thank you for your answear.
I have resetted to factory defaults everything couple of times, including restarting my Thread Board Router (Apple TV) and made some progress.
First of all I have tried to bridge device to Google Home (I don't have Home Assistant access at the moment) as you suggested. And the result was even worse as even Zemismart Hub was not responding.
But i don't need Google Home, so back to Apple HomeKit integration:
When I first bridge Zemismart Hub with Apple HomeKit and then add sub-device (Thermostatic Radiator Valve) via SmartLife then the result is as described in my first post.
But, when I delete Zemismart Hub from my home in Apple HomeKit, and then readd Zemismart Hub to Apple HomeKit again with subdevice already connected to the hub, then Thermostatic Radiator Valve is working almost as expected.
I can view and set temeprature, change working mode (but only on or off).
So, there are two problems right now:
  • cannot add new sub-devices to already connected Hub to Apple HomeKit. I cannot delete and readd Hub to Apple HomeKit every time I add new sub-device, because I will loose automations, etc. configured in Apple HomeKit everytime I do that.
  • cannot set manual/auto working mode via Apple HomeKit, only on/off mode.
New virtual id's:
Gateway: bf01bc60ae4a5633fdgoaa
Valve1: bfd0e02948c5731020dh6b
Valve2: bf4ce24af0931e8466nsyn
Can you share some guidance in this matter?
kafarek
After some more poking around it turns out that if I add unresponding valve to scene in Apple HomeKit and configure it to set the temperature, and then run this scene, the valve becomes fully available and responsive. There is no need to remove and readd Hub back to Apple HomeKit to make it available. :)
So the only request is to change the behavior of "Heat" (Grzanie) mode in Apple HomeKit to set the device to Manual mode, instead of On mode. For me there is no need to expose all four modes, only change the "Heat" mode behavior because it looks like it is not correct. When I use scene or automation in Apple HomeKit to set the desired target tempearture on Valve, it sets the Valve to On mode, instead of Manual mode and the thermostat built in Valve is not used.
fangping.guo
Based on your text and pictures, I understand your requirement: to map Apple Home's Heat mode to Tuya's Manual mode, rather than the On mode. I have made the modification according to your requirements. Please restart the gateway, wait for the conversion file to update, and then verify.
kafarek
I have restarted the gateway and waited approx. 14 hours and verified. Unfortunately, the behavior is still the same. When I set Heat mode in Apple HomeKit the Tuya mode is still On instead of Manual mode. I even removed and added again one of the sub-devices (Valve) to the gateway. Can you make the modifications again or guide me how to update conversion file?
fangping.guo
Again, I have made the modification according to your requirements. Please restart the gateway, wait for the conversion file to update, and then verify.
kafarek
I did as you suggested, restarted the gateway, but no change. Heat mode executes On mode instead of Manual mode. However I don’t know how long should I wait for this „conversion file update” or what it means. I have waited 24 hours. Can I check somehow if this file has been updated or initiate this update manually?
fangping.guo
The conversion file is configured on the cloud. You can trigger the conversion file to be downloaded again by unbinding the device and then rebinding it after a few minutes.
kafarek
Thank you for your assistance. I have readded all my subdevices and the Heat mode works as expected - it switches to Manual mode.
After some more testing I have found one more irregularity:
When I set the Valve to Off (either in Tuya or in HomeKit) the Valve in HomeKit becomes unresponsive (it displays the current temperature, but I cannot control it - cannot chamge work mode from Off to Heat mode). I have to switch mode from Off to Manual in Tuya to make the Valve responsive again in HomeKit. I think this worked correctly before the latest changes in conversion file, but I'm not completely sure. Can you fix this?
Also can you expose battery level of the Valve to HomeKit?
Valve Virtual ID: bf899ace04d5ef3208cpcx
