APP_PATH=apps/tuyaos_demo_quickstart
APP_NAME=tuyaos_demo_quickstart
APP_VERSION=1.0.0
USER_CMD=
/home/z/Documents/tuya/Projects/T2_1/software/TuyaOS/vendor/t2/toolchain/build_path not found in vendor [ t2 ]!
APP_VERSION= 1.0.0
TARGET_PLATFORM= t2
path error: apps/tuyaos_demo_quickstart/app.yaml
grep: make.yaml: 没有那个文件或目录
toolchain Name: t2
toolchain Repo: https://airtake-public-data-1254153901. ... ct/t2_.zip
toolchain Version:
++++++++++++++++++++ the SDK ID tuyaos_demo_quickstart_1.0.0_t2 ++++++++++++++++++++
generate build_param for [ tuyaos_demo_quickstart ] AT [ t2 ]
T2-U DEMO 编译失败
T2-U DEMO 编译失败
Re: T2-U DEMO 编译失败
这个问题和openssl的问题不一样
- chenyisong
Re: T2-U DEMO 编译失败
我这边测试了T2的2个版本,3.3.4和3.8.4,均可以正常下载到T2_1.4.0.zip 和T2_1.5.0.zip文件
https://airtake-public-data-1254153901. ... _1.4.0.zip
https://airtake-public-data-1254153901. ... _1.5.0.zip
我看你这边发的这个链接地址https://airtake-public-data-1254153901.cos.ap-shanghai.myqcloud.com/smart/embed/pruduct/t2.zip,t2.zip没有对应的版本号,所以下载失败了
Re: T2-U DEMO 编译失败
USER_CMD=
我发现正常编译的没有这一条信息
Re: T2-U DEMO 编译失败
USER_CMD=
这是编译正常的
- chenyisong
Re: T2-U DEMO 编译失败
wzf 2024年 Mar 18日 14:39USER_CMD=
/home/z/Documents/tuya/Projects/T2_1/software/TuyaOS/vendor/t2/toolchain/build_path not found in vend我发现正常编译的没有这一条信息
就是因为T2_1.4.0.zip或者T2_1.5.0.zip没有下载下来,编译报错了,错误:为/home/z/Documents/tuya/Projects/T2_1/software/TuyaOS/vendor/t2 这个目录没有
