- Tuya MiniApp IDE 版本信息:~ 0.10.7
- @ray-js/ray, @ray-js/panel-sdk的版本:
"@ray-js/charts-library": "^0.0.3", "@ray-js/common-charts": "^0.1.9", "@ray-js/panel-sdk": "^1.14.1", "@ray-js/ray": "^1.7.55", "@ray-js/ray-error-catch": "^0.0.26", "@ray-js/smart-ui": "^2.7.2", - 相关代码:
<ChartPeriodProvider initialGranularity="day"> <View> <ChartGranularityPicker options={['day', 'week', 'month', 'year']} /> <ChartPeriodNavigator /> <ChartSeriesPanel chartProps={{ customStyle: { width: '100%', height: '240px', }, }} /> </View> </ChartPeriodProvider> </DataSourceProvider> - 日志信息:
[Template] Tag <core-index-920496 /> attribute: "option" is not supported <Builtin: HTMLElement> [Template] Tag <core-index-920496 /> attribute: "theme" is not supported <Builtin: HTMLElement> [Template] Tag <core-index-920496 /> attribute: "unit" is not supported <Builtin: HTMLElement> [Template] Tag <core-index-920496 /> attribute: "opts" is not supported <Builtin: HTMLElement> [Template] Tag <core-index-920496 /> attribute: "usingPluginList" is not supported <Builtin: HTMLElement> [Template] Tag <core-index-920496 /> attribute: "__p__" is not supported <Builtin: HTMLElement> [Template] Tag <core-index-920496 /> attribute: "__instid__" is not supported <Builtin: HTMLElement> ...(共 22 条,覆盖所有属性,且重复刷出多轮)
排查过程Code: Select all
- 问题描述(复现步骤):面板小程序中,使用 @ray-js/charts-library 绘制用水量图表,图表完全不渲染,控制台刷出大量警告。 - AI的问题描述:定位到 <core-index-920496> 被当作普通 HTMLElement
日志中 attribute: "xxx" is not supported <Builtin: HTMLElement> 表明 <core-index-920496> 被运行时当作内置 HTML 元素而非自定义组件。原生 ECharts 组件定义在 @tuya-miniapp/common-charts/lib/core/index.js(含 Component({ properties: { option, theme, ... } })),属性声明完整,但运行时根本没加载到该组件。对比构建产物 — usingComponents 缺失
查看 dist/tuya/pages/home/index.json:
应用
"usingComponents": {
"button-index-6f98db": "/npm/@tuya-miniapp/smart-ui/dist/button/index",
"icon-index-5f5544": "/npm/@tuya-miniapp/smart-ui/dist/icon/index",
"nav-bar-index-404ec1": "/_npm/@tuya-miniapp/smart-ui/dist/nav-bar/index"
//没有任何 common-charts 的条目!
而 smart-ui 的组件都正常注册了。同样的 _npm/@tuya-miniapp/common-charts/lib/core/ 目录下文件完整(index.js / .json / .tyml / .tyss / .rjs),说明文件已经复制到了构建产物中,但页面的 usingComponents 里漏掉了它。
- 对比 smart-ui — 差异在 auto-import 机制
smart-ui 能自动注册是因为 ray.config.ts 里配置了 SmartUIAutoImport:
应用
// ray.config.ts
import SmartUIAutoImport from '@ray-js/smart-ui/lib/auto-import';
const config: RayConfig = {
importTransformer: [SmartUIAutoImport],
这会让构建系统把 smart-ui 原生组件的 import 注入到项目源码中,babel-plugin-remax-host-component 检测到后自动生成 usingComponents 映射。
而 @ray-js/charts-library 内部使用 CommonCharts(@tuya-miniapp/common-charts)的方式是预构建包内部的 JSX:
js
应用
// @ray-js/common-charts/lib/index.js(预构建)
import CommonCharts from '@tuya-miniapp/common-charts';
return React.createElement(CommonCharts, { option, theme, ... });
这个 JSX 在预构建的 .js 文件里,不像 smart-ui 那样有 auto-import 把 import 暴露到项目源码层,babel 插件追踪不到,所以 usingComponents 里永远不会有 common-charts。
Ray 小程序使用 @ray-js/charts-library 图表不渲染,报错
