【LampModuleSchedule】点击更新 timer 的开关时整个列表会闪烁
  • Tuya MiniApp IDE 版本信息:0.8.9;
    • App 应用版本信息: 6.4.0;
    • @ray-js/ray, @ray-js/panel-sdk的版本:"@ray-js/ray": "1.6.1";"@ray-js/panel-sdk": "1.13.1";
    • 移动设备信息:iPhone 13 Pro
    • 相关代码:
      import React, { useState, useEffect } from 'react';
      import { View, ScrollView } from '@ray-js/ray';
      import { useActions, useProps, useDevInfo } from '@ray-js/panel-sdk';
      import { TopBar } from '@/components';
      import Strings from '@/i18n';
      import LampModuleSchedule, {
        useCountdownTime,
        useCountdownDpPull,
        useTriggerChildrenFunction,
      } from '@ray-js/lamp-module-schedule';
      import { getCachedSystemInfo } from '@/api/getCachedSystemInfo';
      import styles from './index.module.less';
      const sysInfo = getCachedSystemInfo();
       *定时就这样:分成四种。分别是开灯开风扇,开灯关风扇,关灯开风扇,关灯关风扇。
      const dpCodes = {
        switchCode: 'switch_led', // 20
        colorSwitchCode: 'switch_rgb', // 104
        countdownCode: 'countdown',
        rtcTimerCode: 'rtc_timer',
        workModeCode: 'woke_mode',
        fanSwitchCode: 'fan_switch', // 60
      // 根据需求自行调整
      const actionList = [
          label: Strings.getLang('schedule_action_0'), // 开启
          dpList: [
              value: true,
              code: dpCodes.switchCode,
          label: Strings.getLang('schedule_action_1'),
          dpList: [
              value: false,
              code: dpCodes.fanSwitchCode,
      const Main = () => {
        const deviceInfo = useDevInfo();
        const countdown = useProps(dp => dp.countdown);
        const actions = useActions();
        const [_countdown, setCountdown] = useState(0);
        // 由于dp获取后不会变化,倒计时数据需要自行进行处理
        useCountdownTime(_countdown, (_countdown: number) => {
          // 进行倒计时更新
          setCountdown(_countdown);
          if (_countdown <= 0) {
            // 下发dp
            actions.countdown.set(0);
        useEffect(() => {
          if (countdown) {
            setCountdown(countdown);
            return;
          if (countdown <= 0) {
            setCountdown(0);
        }, [countdown]);
        const _onCountdownToggle = (_countdown: number) => {
          console.log(_countdown, 'onCountdownToggle');
            // 下发dp
        // const { run: runTimerToggle } = useTriggerChildrenFunction('timerToggle');
        // // mock dp触发定时状态修改
        // useEffect(() => {
        //   setTimeout(() => {
        //     const timerId = 1;
        //     const timerStatus = false;
        //     runTimerToggle(timerId, timerStatus);
        //   }, 4000);
        // sigmesh协议下需要主动拉取倒计时dp值,防止倒计时dp不同步
        const dpId = 26; // TODO:
        useCountdownDpPull(deviceInfo.devId, dpId);
        return (
          <View className={styles.view} style={{ paddingTop: `${sysInfo.statusBarHeight}px` }}>
            <TopBar title={Strings.schedule} />
            <ScrollView scrollY className={styles.scheduleView}>
              <LampModuleSchedule
                devId={deviceInfo?.devId}
                groupId={deviceInfo?.groupId}
                supportCountdown
                supportCloudTimer
                supportRctTimer
                showHeader={false}
                countdownConfig={{
                  countdown: _countdown,
                style={{ height: '90vh' }}
                timingConfig={{
                  actionList,
                  timerLimitNum: 6,
                themeConfig={{
                  theme: 'dark',
                  // 整体背景色
                  background: '#000',
                  // 品牌色
                  brandColor: '#1082FE',
                  // 字体颜色
                  fontColor: {
                    titlePrimary: '#FFFFFF', // 主要标题文字颜色
                    textPrimary: '#FFFFFF', // 主要文字颜色
                    textRegular: 'rgba(255, 255, 255, 0.5)', // 常规文字颜色
                  // 卡片样式
                  card: {
                    background: '#1F2022', // 卡片背景色
                    borderColor: 'rgba(255, 255, 255, 0.102054)',
                    textPrimary: '#fff',
                  // 时间选择器样式
                  timer: {
                    background: 'rgba(0, 0, 0, 1)', // 背景色
                    timerPickerBorderColor: 'rgba(255, 255, 255, 0.5)', // 分割线颜色
                    customStyle: {
                      color: '#fff', // 自定义周期文字颜色
                      borderColor: 'rgba(255, 255, 255, 0.1)', // 自定义周期边框颜色
                      background: 'rgba(0, 0, 0, 1)', // 自定义周期卡片背景色
                onBeforeTimerChange={(res, type, timerList) => {
                  console.log(res, type, timerList, 'onBeforeTimerChange');
                  // 支持异步
                  // return new Promise(resolve => {
                  //     resolve(true);
                  //   }, 100);
                  // 同步
                  return true;
                onCountdownToggle={(_countdown: number) => {
                  _onCountdownToggle(_countdown);
                onRtcTimeAdd={timerData => {
                  console.log(timerData, 'onRtcTimeAdd');
                onRtcTimeRemove={timerData => {
                  console.log(timerData, 'onRtcTimeRemove');
                onRtcTimeUpdate={timerData => {
                  console.log(timerData, 'onRtcTimeUpdate');
            </ScrollView>
          </View>
      export default Main;
      .countdownView {
        width: 100vw;
        height: 100vh;
        background-color: #000;
        .scheduleView {
          width: 100vw;
          height: calc(100vh - 50px);
          padding-bottom: 20px;
      // 定时组件样式 bug
      :global(.countdown-card-mask) {
        bottom: 0 !important;
        top: auto !important;
      - 日志信息:~错误日志或 IDE 运行日志等~
      - 问题描述(复现步骤):"@ray-js/lamp-module-schedule": "^0.2.30" ; LampModuleSchedule 的定时列表中单独的定时任务 timer 点击开关,更新的时候整个列表的 timer 内容会跟着闪烁
      - 预期结果: 更新 timer 开关时列表不闪烁
      - 实际结果:更新 timer 开关时列表闪烁
crisiron
Re: 【LampModuleSchedule】点击更新 timer 的开关时整个列表会闪烁
感谢反馈,麻烦更新下
 yarn add --registry=https://registry.npmjs.org/@ray-js/lamp-module-schedule@0.2.31-beta-3
版本,然后在 package.json中配置
"resolutions": {
"@ray-js/lamp-module-schedule": "0.2.31-beta-3"
}, 测试没问题后反馈下 我发布下正式版本
15002075425
crisiron 2025年 May 19日 10:31
感谢反馈,麻烦更新下
"resolutions": {
测试过没问题,已解决
crisiron
正式版本已发布:yarn add --registry=https://registry.npmjs.org/ @ray-js/lamp-module-schedule@0.2.31
