Presence sensor not imported matter
unnamedi
I have a presence sensor that is not being imported via matter.
Could you add it?
Hub Zemismart M6:
Device ID: eb51fac4c4e08c557eqpjz
presence sensor:
Device ID: eb99d00f3d9b78ffa9t5hr
fangping.guo
Re: Presence sensor not imported matter
Done. Please restart the matter gateway for verification.
unnamedi
Thank you, it's working correctly. However, it came as a battery-powered device on SmartThings, but it isn't.
fangping.guo
OK, I have updated and removed the battery function. You need to unbind the device, restart the gateway, and rebind the device to verify.
unnamedi
It worked perfectly. Thank you very much.
However, I just noticed that a temperature and humidity sensor isn't working correctly in the Tuya app.
Everything is fine with the correct report, but in SmartThings, Home Assistant, and HomeKit, it doesn't show the correct temperature and humidity, only fixed numbers.
I also noticed that it's missing the "battery no matter" entity.
Device ID:
ebc5f82d75559bf19euabf
fangping.guo
I have tested the products corresponding to the device IDs you provided, and found no issues such as data errors or incorrect battery level display. Perhaps you can also reset or unbind it and then rebind it.
