Zigbee VRF thermostat Not Exposed via Matter
Hollako
Hello,
I have a Zigbee VRF thermostat that is not shared via Matter with the following ID:
  • bfda6dc433ad9b142dqgyg
Please support to add it to the devices shared over Matter.
Thank you in advance for the support.
fangping.guo
Re: Zigbee VRF thermostat Not Exposed via Matter
Hello, the device is now capable of bridging. Please restart the Matter gateway to verify.
Hollako
Hello,
Now i can see the thermostat however still many parameters need to be adjusted/added:
1- Temperatures should be devided by 10, for example i see the temperature 250 where it's 25.0 and the same for the setpoint.
2- This VRF Thermostat should support Heat/Cool/Fan/Off but I only see Heat and Off
3- There is also Fan Speed Control High/Medium/Low/Auto, not shown at all.
Thanks in advance for your support.
fangping.guo
Hello, the configuration has been updated. Please restart the gateway to verify. The mode switching you mentioned is not currently supported.
Hollako
Hello,
The Temperature and Setpoint are Ok now. Too bad the other parameters not supported for now. Any idea if they will be supported soon? without them the integration is useless. Currently I can't put the thermostat to Cool or change fan speed.
