T1模组编译产物无UG固件
alingbaba
SDK版本:T1_TuyaOS-3.11.25
开发环境:VS Code Tuya Wind IDE
编译成功输出产物只有QIO和UA固件,无UG固件
ibs/ -ltuyaapp_components -ltuyaapp_drivers -ltuyaos -T./T1/build/bk7238_ota.ld -Xlinker -Map=../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.map
#../toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-nm ../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.axf | sort > ../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.map
../toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-objdump -d ../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.axf > ../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.asm
../toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-objcopy -O binary ../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.axf ../../../apps/smart_display_box/output/1.0.0/smart_display_box_1.0.0.bin
make[2]: Leaving directory '/root/Documents/tuya/Projects/T1_TuyaOS-3.11.25/software/TuyaOS/vendor/T1/T1_os'
make[1]: Leaving directory '/root/Documents/tuya/Projects/T1_TuyaOS-3.11.25/software/TuyaOS/vendor/T1/T1_os'
Start Combined
/< @author jiewu@bekencorp.com */
< @version v0.3 */
Encrypt Seccessfully!
-FileSize: 0xf6a86
ua_file size:
1500000
/root/Documents/tuya/Projects/T1_TuyaOS-3.11.25/software/TuyaOS/vendor/T1/T1_os/tools/generate
AD720
build.sh: 149: bc: not found
make: *** [/root/Documents/tuya/Projects/T1_TuyaOS-3.11.25/software/TuyaOS/scripts/mk/app.mk:195: app_by_name] Error 127
