Water Level Sensor
edlei@hotmail.com.br
Hello, is there any prediction of the water level sensor being exported via Matter to Google Home?
fangping.guo
Re: Water Level Sensor
I've configured the device as a water leak sensor, where a liquid_state value of 0 represents normal (no leak), and values of 1 or 2 indicate a water leak.
I don't understand.
fangping.guo
What would you like me to do?
fangping.guo
You can restart the gateway to verify if the device appears on the Google Home platform.
Yes, it appeared, but I still don't understand how I can use it exported as a leak sensor?
fangping.guo
I'm sorry, I don't understand what your confusion is.
It's not a leak sensor, it's a water level sensor.
https://a.aliexpress.com/_mMKwCH3
fangping.guo
However, Matter does not support water level sensors.
I could put it as a thermostat, where would the percentage of the volume of water be the measured degrees?
