MMwave sensor showing low battery
Mathmock
I have a zigbee presence sensor MMwave virtual ID eb96605b4299439c32bv6l connected to the Hub Zigbee ID virtual eba6ffcbd9c94db8be2dxl. When exporting to ST by Matter the sensor is shown without battery but the sensor is not the battery, it is connected to power.
Can you help me?
fangping.guo
Re: MMwave sensor showing low battery
Hello, I have updated the configuration for your device.
Please try restarting the gateway or unbinding the device and trying again.
Mathmock
Very good, it worked. If I add a new sensor like this one, will I have to fix it again or is this correction for everyone?
fangping.guo
If the product ID of the new device matches this one (generally the same for identical models), no reconfiguration is required.
